overheating!!!
i have a turbocharged 00 civic si and my car starts getting hot after i stay still for about 5 min. when i check my reserve tank its always filled... i changed the thermostat and the radiator cap and its keeps doing it. can anyone help me out??
Try flushing your coolant and repalce the coolant with a mixture using more water than coolant.. Water holds heat better while coolant has a higher boiling point. Correct me if im wrong.
i just went to burp the water system and as i was accelerating waiting for the water to go down, it started to bubble up white bubbles on the radiator. do u guys think its the headgasket?? i got a cometic one so i dont think it could be that. anything else it could be ?? warped head?
where the bubbles like milky white thick looking. Take you sprak plugs out and see if you can see any water in the cyl's. Pull your dipstick out and see if there is milky white substance on it, or even go as far as removing the valvecover to take a better look at the oil. It could just be a thermostat too did you try changing it yet since its cheap and easy?
they were not thick more like just white and really bubbly. no milky white substance on dipstick, and i changed the thermostat but it was a autozone thermostat. i read yesterday someone saying that those are defective?? could it be that??
yes, i did change the thermostat. i was reading up on this and i read the the autozone thermostats suck? that they work for like 3 days then they mess up again... well mine worked for about 5 days then it started overheating again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec »</TD></TR><TR><TD CLASS="quote">HE ALREADY DID THAT DID YOU NOT READ THE POST
HEY YOU DUMBAZZ READ HIS POST!!!
I would get a stock Honda one. You're having issues with overheating, but there's no residue in the oil. That's a thermostat, and air in the head.
</TD></TR></TABLE>HEY YOU DUMBAZZ READ HIS POST!!!
you do not know what you are talking about you can blow through to the water jacket only too you do not have to have coolant in the oil to tell you have a bad head gasket
Yeah but if it was a head gasket wouldn't you loose coolant? mine just fills the resivour. if you let it cool and pour from the catch can to the radator it fills the radator just fine???
kinda wondering myself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK2NR »</TD></TR><TR><TD CLASS="quote">Yeah but if it was a head gasket wouldn't you loose coolant? mine just fills the resivour. if you let it cool and pour from the catch can to the radator it fills the radator just fine???
kinda wondering myself</TD></TR></TABLE>
no , because you can blow the gasket between the water jacket , thus it will pressurize the cooling system pushing coolant out of the engine and into the catch tank.
trust me this is common
hopefully its just the headgasket and not a warped head. i was wondering i have arp head studs, was i supposed to retorque them after a certain amount of miles?? also , so it is possible for the cometic 3 layered hg to blow rigth??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 »</TD></TR><TR><TD CLASS="quote">hopefully its just the headgasket and not a warped head. i was wondering i have arp head studs, was i supposed to retorque them after a certain amount of miles?? also , so it is possible for the cometic 3 layered hg to blow rigth??</TD></TR></TABLE>
did it do it right after the headgasket and stud change? if so your head is warped.
mine started to do it again after like a month...i think my head is warped , i have arp studs and a cometic gasket
