overheating!!!
Old Mar 9, 2004 | 08:11 AM
  #26
bluesi00's Avatar
yeah they come on , but not always... i dont know why they do that, i figure if they turn on then they must be ok right?? just that they dont turn on sometimes when the car starts overheating
Old Mar 9, 2004 | 09:55 AM
  #27
Griffin@Camtech's Avatar
Default Re: overheating!!! (bluesi00)
free bump
Old Mar 9, 2004 | 10:06 AM
  #28
ykracing's Avatar
Default Re: (bluesi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 &raquo;</TD></TR><TR><TD CLASS="quote"> so it is possible for the cometic 3 layered hg to blow rigth??</TD></TR></TABLE>
any head gasket can blow...
anybody who told you that your cometic wont blow, was lying...
good luck with the fix tho...
Old Mar 9, 2004 | 10:09 AM
  #29
RGAZ's Avatar
New User
Default Re: (trboCIVICWRX)
BHG.
Nothing more to say.
R
Old Mar 9, 2004 | 02:57 PM
  #30
ATS*Mark's Avatar
OG triple OG
Default Re: (RGAZ)
yep , i gotta change my cometic today too
Old Mar 9, 2004 | 10:36 PM
  #31
bluesi00's Avatar
ok, i couldnt get a hold of a leak down tester(cant find one) so i did a compression test , here are the results
185 185 165 185
Old Mar 9, 2004 | 10:50 PM
  #32
Darin D.'s Avatar
I love how everyone assumes it's the headgasket when someones car overheats.
From the way you describe the problem, it sounds like the radiator fan isn't coming on. Fairly simple to check, just jump the connector on the theromstat housing so the fans stay on all the time and see if it still heats up.
Also, the way the water bubbles up like that is normal. When the car is hot, thermostat is open, pump is flowing and you have enough water in the system it will bubble up and overflow like that without the cap on.
If the car only overheats at idle, i can pretty much guarantee it's a faulty fan switch or fan.
Old Mar 9, 2004 | 10:53 PM
  #33
ATS*Mark's Avatar
OG triple OG
Default Re: (Willis)
you guys are not reading his problem..... coolant is getting pushed into the overflow tank , it wont do that if his fan isnt comming on.
so i love how you wont fully read his problem. ive seen this a million times.
Old Mar 9, 2004 | 10:54 PM
  #34
bluesi00's Avatar
yeah, but when i turn on my car its like if the system gets pressure and it throws water out to the reserve tank...
Old Mar 9, 2004 | 11:03 PM
  #35
ATS*Mark's Avatar
OG triple OG
thermal expansion and contraction
Old Mar 9, 2004 | 11:06 PM
  #36
lazerus's Avatar
Default Re: (Hella_JDM)
You said turbo overheat, and coolant overflow all in the same paragraph.
since its at idle, then its not your headgasket. its got to be your coolant fan.
Modified by lazerus at 2:20 AM 3/10/2004
Old Mar 9, 2004 | 11:16 PM
  #37
Darin D.'s Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">you guys are not reading his problem..... coolant is getting pushed into the overflow tank , it wont do that if his fan isnt comming on.
so i love how you wont fully read his problem. ive seen this a million times.</TD></TR></TABLE>
If you've seen it a million times you would know that's what happens when an engine overheats. the hotter the engine gets the more coolant will flow into the overflow....so if his car is overheating i would expect his overflow tank to fill up or overflow.
Old Mar 9, 2004 | 11:27 PM
  #38
ATS*Mark's Avatar
OG triple OG
i dont see it as the car is overheating so coolant is getting pushed into the catch tank.
i see it as the blown headgasket is alowing coolant to be pushed into the overflow , making the car overheat
Old Mar 9, 2004 | 11:42 PM
  #39
Darin D.'s Avatar
haha.
ok, so what clues lead you to believe it's the headgasket then? Since you've seen it a million times..
If this guy had a blown headgasket it would overheat all the time, not just at idle.
Old Mar 10, 2004 | 01:53 AM
  #40
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">i dont see it as the car is overheating so coolant is getting pushed into the catch tank.
i see it as the blown headgasket is alowing coolant to be pushed into the overflow , making the car overheat</TD></TR></TABLE>
DID YOU MISS THE PART WHERE HE SAID THERE WAS NO GUNK ANYWHERE IT DID NOT BELONG?
Did I get it to stick this time? It' not a head gasket.
I never thought about the cooling fan... Never had that problem before. Still sounds to me like his thermo is sticking, though. He should check his fan first though it's cheaper to fix.
Old Mar 10, 2004 | 03:15 AM
  #41
ATS*Mark's Avatar
OG triple OG
Default Re: (nd_styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd_styles &raquo;</TD></TR><TR><TD CLASS="quote">
I never thought about the cooling fan... Never had that problem before. Still sounds to me like his thermo is sticking, though. He should check his fan first though it's cheaper to fix. </TD></TR></TABLE>
my blown headgasket didnt mix coolant and oil either you ******* moron
Old Mar 10, 2004 | 03:27 AM
  #42
1.8turbolsvtec's Avatar
THANKYOU HELLA-JDM THAT GUY COULD NOT FIND HIS WAY AROUND A GOLF CART
IT IS THE ******* HEAD GASKET GOOD LUCK
Old Mar 10, 2004 | 03:39 AM
  #43
Nid Styles's Avatar
my blown headgasket didnt mix coolant and oil either you ******* moron</TD></TR></TABLE>
Did your car only overheat why idleing, and sitting still? Go f#ck yourself moron.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
IT IS THE ******* HEAD GASKET GOOD LUCK</TD></TR></TABLE>
Nice that you know me so well. I'd have to have been around a Go-Kart to know my way around one right? I've never even rode in one. Sorry I'm not so privileged.
Old Mar 10, 2004 | 04:52 AM
  #44
ATS*Mark's Avatar
OG triple OG
as a matter yes it did , and my heat didnt work either......
Old Mar 10, 2004 | 04:57 AM
  #45
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 &raquo;</TD></TR><TR><TD CLASS="quote">ok, i couldnt get a hold of a leak down tester(cant find one) so i did a compression test , here are the results
185 185 165 185</TD></TR></TABLE>
and my numbers were basically even across the board just like that as well
Old Mar 10, 2004 | 05:09 AM
  #46
hey how about this? test the fans, pressure test the cooling system if nothing else is at fault change the head gasket???
try the simple stuff first. in the amont of time we wasted talking about this his problem could be solved.
mine was doing the same thing. it was the thermostat.
not saying his isn't a head gasket.
just try the easy stuff first
Old Mar 10, 2004 | 05:58 AM
  #47
GDM Z28's Avatar
Default Re: (EK2NR)
i had the same thing happen to me!! people said it was the HG. it ended up being the radiator it self. use a friends radiator n see if it solves your problem. but make sure you bleed all the air out of the system after you change radiators.
or if thats not the problem, when it starts to over heat hold your car at 5k or 5.5k rpms and see if it holds temp or drops. if it does it might be your water pump. same thing happen to me 2.
Old Mar 10, 2004 | 06:53 AM
  #48
turbosi03's Avatar
Default Re: (civicflnum1)
ahhh guys the drama...
I had the EXACT same simptoms and it turned out that my sleeves moved which means the gasket wasn't sealing right... so it very well COULD be the head gasket...
now I'm no mechanic but I wouldn't just go changing radiators and replacing head gaskets and all that ****. do a FULL inspection of the entire cooling system first. then if the thermostat, radiator, water pump, etc... is working properly, and there is still too much pressure in the cooling system, then I would look at the head gasket.
I just think it easier to pull and check the thermostat, pressure test the radiator, and all that stuff before pulling the head... but again thats because I'm no mechanic.
There are too many configurations that produce the same problems, so I wont say for sure it's the HG... but since it happend to me and it was the HG I'm going to lean in that direction...
Old Mar 10, 2004 | 09:46 AM
  #49
bluesi00's Avatar
yeah... im gonna go get a oem thermostat from honda and see if that fixes the problem , if not i'll do the leakdown test... i'll keep u guys informed thanks
Old Mar 10, 2004 | 01:04 PM
  #50
vtec.dc2's Avatar
you could do a cooling system pressure test, you'll be able to hear if theres a leak.
