Overheating.....
Old Mar 16, 2005 | 03:23 PM
...emu...'s Avatar
Default Overheating.....
When I cruise my car over about 65mph my EGT gauge is reading roughly 1200 degrees F. I know that this is way to hot and was wondering if there are any easy solutions. btw: I'm running a Drag 3 turbo kiton a stock motor with 440cc injectors, and a VAFC II, and only running 8psi. Does anyone have any ideas? Also what is the hottest that is still safe...? Sorry if this is real basic... Thanks in advance.
Old Mar 16, 2005 | 03:29 PM
...emu...'s Avatar
Bump
Old Mar 16, 2005 | 03:33 PM
...emu...'s Avatar
please help an emu kid....
Old Mar 16, 2005 | 03:41 PM
platinum00's Avatar
Default Re: Overheating..... (milanoturbosi)
where is your EGT probe located. on the 3rd runner ?
do you know what your A/F looks like ?
to know what your safe point depends on your internals, if there stock i think it's like ~1300 or something. im not sure on that.
Old Mar 16, 2005 | 03:45 PM
...emu...'s Avatar
my egt is located on the third runner
and my a/f is under 1.... someone told me that with hondata this problem would go away...but then again they want more of my money so idk.
Old Mar 16, 2005 | 04:21 PM
XSIintegra's Avatar
Default Re: (milanoturbosi)
a/f uner 1???
Anyways, 1200f should be fine. Most DSM guys I've chatted with (and it three weeks-myself) tune out around 1500degrees. Past that...your getting hot.
Old Mar 16, 2005 | 07:00 PM
...emu...'s Avatar
Thats what i figured...so just like i thought the shop where i had all my work done was trying to get another few grand outta me...thx guys
Old Mar 16, 2005 | 08:11 PM
Blackack26's Avatar
Im tapped 1" away from the head on the third runner and my highway cruising temps are usually 1400 F
Dont get to worried about egts... unless they are abnormally high, or low
Old Mar 16, 2005 | 08:41 PM
ppfalcon's Avatar
if its a stock motor you need to upgrade you cooling capabilities for your engine, better radiator, oil cooler, and do mixture of 10% redline 40% radiator fluid and %50 percent water
Old Mar 17, 2005 | 02:51 PM
...emu...'s Avatar
Thanks alot guys...this is really good info
CO_HaTcH
Apr 26, 2007 07:22 AM
oemDC2
Nov 22, 2003 09:41 AM
95stangkillah
Jun 20, 2003 06:33 AM
bcause
Apr 27, 2002 02:54 PM
K1R
Nov 25, 2001 07:40 PM
