Overheating.....
When I cruise my car over about 65mph my EGT gauge is reading roughly 1200 degrees F. I know that this is way to hot and was wondering if there are any easy solutions. btw: I'm running a Drag 3 turbo kiton a stock motor with 440cc injectors, and a VAFC II, and only running 8psi. Does anyone have any ideas? Also what is the hottest that is still safe...? Sorry if this is real basic... Thanks in advance.
where is your EGT probe located. on the 3rd runner ?
do you know what your A/F looks like ?
to know what your safe point depends on your internals, if there stock i think it's like ~1300 or something. im not sure on that.
my egt is located on the third runner
and my a/f is under 1.... someone told me that with hondata this problem would go away...but then again they want more of my money so idk.
Im tapped 1" away from the head on the third runner and my highway cruising temps are usually 1400 F
Dont get to worried about egts... unless they are abnormally high, or low
if its a stock motor you need to upgrade you cooling capabilities for your engine, better radiator, oil cooler, and do mixture of 10% redline 40% radiator fluid and %50 percent water
CO_HaTcH
Apr 26, 2007 07:22 AM
