Overboosting?
Old Nov 2, 2009 | 02:20 PM
  #26
Urban_Indian's Avatar
Default Re: Overboosting?
Originally Posted by N3va3vaSatisfi3d
LOL, naw nothing, but glad to hear you fixed it and didn't just throw parts at it. There is always rhyme and reason for problems.
If your car JUST STARTS doing something out of no where for no reason. You didnt change anything.... then its most likely something has degraded or become loose, not aligned etc etc..
Search the reason why before throwing money at it because you will most likely buy something that will not fix your problem and you will just get pissed off because you wasted money and your **** is still broken
Old Nov 2, 2009 | 07:53 PM
  #27
turbod16y8's Avatar
try spraying some wd40 on the acuator arm see if that helps.
Old Nov 3, 2009 | 04:42 AM
  #28
D-Rob's Avatar
Originally Posted by linkdeezie
...and i bet the reason ur car is breaking up when u hit that 11/12 lbs boost mark is because ur using a STOCK MAP sensor, and NO missing link....replace the sensor with an aftermarket one or use a missing link. I'd recommend replacement tho...
Please don't use a Missing Link.
:facepalm:
Old Nov 3, 2009 | 07:50 AM
  #29
pettyboy69's Avatar
ya stock maps are only good for 11.2lbs correct? and in my experience the more boost you run and the closer to the max of the stock map the less accurate they are. the money thing made me lol ha ha ha
Old Nov 3, 2009 | 02:55 PM
  #30
LS AzZkIkr's Avatar
When the weather here in central VA started getting around 55 my car started to hit boost cut and the only thing I can think of is the colder air? But it looks like you have solved your problem.
Old Nov 3, 2009 | 04:19 PM
  #31
01 LudeDude's Avatar
Same here in Ohio. When it got cold out I started to hit boost cut @24psi, which is creeping 2 psi from set point. I don't know the exact cause but I'm guessing because the air is colder/denser(therefor slightly compressed already) that is creating the extra few PSI? Sure seemed like it started just as it really got cold out.
tyoung
Jul 18, 2008 02:06 AM
OHmotorsports
Sep 11, 2007 02:51 PM
junk in the trunk
May 11, 2007 03:58 PM
SPOOLINmatt
Mar 20, 2006 01:21 PM
Nihilation
Sep 10, 2004 01:24 PM
