overboost
Old Nov 25, 2002 | 07:22 AM
WONG FRIED RICE's Avatar
Default overboost
i did a search and i don't think this has been discussed before if it has i'm sorry i didn't find it... but anyhow.. I'm running a drag kit on my d16y8 motor. Ported & polished head, 5 angle valve job. I'm running hondata s200 management, 440cc injectors, high flow fuel pump, adjustable fuel regulator, 2.5 inch exhaust system to the turbo, straight pipe included.
Now my problem is that in second gear, third gear, and fourth the car boosts up to 10 psi and higher. I'm using the deltagate wastegate with a 7lb spring. (thats what i have so please don't say get a different one ) I turned the screw on the top all the way out until there's no more tension and i turned one full turn back so that it is right on the edge of tension. From what i know, i should be boosting minimum. But its not. 1st gear i can't hit high boost, but 2nd goes easily to 10lbs. I can't use my VTEC because when i hit around 5000RPMS the car is already at 10psi. I tried one max run but at 5500-5750 i hit 15lbs, and couldn't rev past 5500 (way too lean, about 14.3:1 a/f ratio...courtesy of motec wide band o2).
Is my wastegate hooked up wrong? I have one independant vaccum line to the side of the wastegate, and one from the top of the wastegate to the turbine vaccum outlet.
Old Nov 25, 2002 | 07:27 AM
GraphiteAccord's Avatar
Default Re: overboost (JDMB16ACRX)
you can afford a motec, but not a tail wastegate?
Old Nov 25, 2002 | 09:09 AM
PeakBoost's Avatar
B*A*N*N*E*D
you need to have the vacuum line connected to the vacuum port on the wastegate(side) only...
the way that you have it right now, the 2 ports are receiving the same vacuum/boost readings and have no way of opening the valve.
just remove the top vacuum line, leave it open and you will be all set.
Old Nov 25, 2002 | 09:41 AM
Default Re: overboost (GraphiteAccord)
i want to use the deltagate because i want to try and make it work
plus its not a Motec System, its just a wide band o2 sensor.
cheapturbo: okay thanks i will try disconnecting it and see what happens.
[Modified by JDMB16ACRX, 10:42 AM 11/25/2002]
cannon_si
Engine Management and Tuning
12
Oct 17, 2010 06:54 PM
blackeg
Aug 9, 2010 04:31 PM
nyjdmhatch
Jun 22, 2005 07:59 PM
whackassfawker
Aug 11, 2004 07:27 PM
1CleanSi
Jul 11, 2003 10:46 AM
