Over torqued arp head studs
Old Jul 19, 2005 | 09:01 PM
tub_sephiroth's Avatar
Default Over torqued arp head studs
I torqued my brand new arp head studs to 80 lbs with the moly lube. I did it in two sequence. Should I be worried? Can I loosen and retorque?
Old Jul 20, 2005 | 12:47 PM
doubleA's Avatar
Default Re: Over torqued arp head studs (tub_sephiroth)
Always read the directions, I know its too late. I say loosen and retourque. Ive reused my arp's about 5 times. I dont see why you would have a problem.
Old Jul 20, 2005 | 12:58 PM
.RTErnie's Avatar
Default Re: Over torqued arp head studs (doubleA)
no dont loosen them. Just use them as they are. Just pay attention next time and torque them in like 4-5 steps. I did mine in 8 steps. best to be safe than sorry.
Old Jul 20, 2005 | 01:12 PM
D-tuned's Avatar
Default Re: Over torqued arp head studs (RTErnie Motorsports)
thats what I torque my head studs to but I'm using AEBS. when I was using arps I torqued them down to 76ftlb.
Old Jul 20, 2005 | 01:15 PM
b16hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">no dont loosen them. Just use them as they are. Just pay attention next time and torque them in like 4-5 steps. I did mine in 8 steps. best to be safe than sorry. </TD></TR></TABLE>
3-4 steps is plenty. If its your first time torquing them, loosen and retorque them to the same specs about 3 times so you don't have to pull the cams to retorque them in a few hundred miles.
Old Jul 21, 2005 | 05:51 AM
Default Re: Over torqued arp head studs (b16hybridsol)
If I loosen them and retorque to 70 lbs. Wouldn't my hg leak now because I already torqued the hg down to 80 lbs before?
Old Jul 21, 2005 | 06:15 AM
mike1114's Avatar
No it will be fine. I even took the head back off after tourqing down (forgot dowel pin in cam cap) and put it back on, tq'ed back down and everythings fine 10-15psi later!!!
Old Jul 21, 2005 | 09:47 AM
stizzit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">3-4 steps is plenty. If its your first time torquing them, loosen and retorque them to the same specs about 3 times so you don't have to pull the cams to retorque them in a few hundred miles. </TD></TR></TABLE>
Umm you would still need to retorque them anyhow because after the block reaches operating temperature, the threads expand at a different rate than the studs, etc.
Retorquing it cold is just about as useless as washing my car three times in a row
Old Aug 17, 2005 | 06:11 PM
asubennett's Avatar
Default Re: Over torqued arp head studs (stizzit)
Not true. You are trying to reach an optimal amount of stretch. Just like rod bolts. Once this has been done. You are done.
Old Aug 17, 2005 | 07:00 PM
Sketch_hs's Avatar
yes it's about the bolt stretch
ARP stuff doesn't change after heat cycle according to ARP
Old Aug 22, 2005 | 08:57 PM
eg:R's Avatar
what are the steps?? will be putting my head on soon
Old Aug 22, 2005 | 09:15 PM
PrecisionH23a's Avatar
Which engine are you running? The H series studs are torqued to 78-80ftlbs.
If you are running D series studs... then yea... you went overboard.
I believe B series are in the low 70's so a few extra lbs is not going to lead to severe bolt stretch. The ARP's are designed to be used time and time again unline stock studs.
The proper way install them is to torque the actual studs in the block, which I put at around 12-15ftlbs then a 3 stage torque sequence. 30-58-79 in the criss-cross sequence as noted in your helms manual.
Old Aug 22, 2005 | 09:58 PM
Default Re: Over torqued arp head studs (PrecisionH23a)
I have a b18c1. Arp says to torque to around 65 lbs with the molylube and 80 lbs with motor oil.
Old Aug 22, 2005 | 10:00 PM
vaporboy12's Avatar
you should be fine
thedudefromjerz
Jun 18, 2008 05:07 AM
Joey.
Jan 7, 2007 10:42 AM
boost fed ls
Jan 6, 2006 06:10 PM
Turbo E
Oct 31, 2004 01:50 PM
eRACING
Aug 15, 2004 08:19 PM
