Over-boosting! Help!!
Old Apr 11, 2006 | 10:38 PM
Makdaddynuge's Avatar
Default Over-boosting! Help!!
References:
JDM gsr block
full-race turbo kit with t3/60-1 and tial 44mm wastegate
Tuned with hondata s300
Ok guys, i just finish my turbo install. Everything went very well, we followed install is done exactly according to full-race website, http://www.full-race.com/artic...s.pdf , except for when we go out to tune it. At first we had the small green spring in the wastegate which according to tial is a 5.8 psi spring. We hit it in first and it creeps on me to 10 pounds; it probably would have went higher but we had boost cut at 10 pounds on the s300. So we try it again, still goes all the way to 10 then boost cut. So we go change the spring to a small yellow, which is a 2.9 psi spring, haha. We go out hit it in 3rd again. Well i hit 3 psi at like 4000 rpms, but at like 6000 rpms it creeps up to 6 psi. Dont' get me wrong, i want like 8 psi, so the creep is fun, but i want to find out why it would be creeping on me. Any ideas? Should i try taping the compressor and using that as my vaccum source for the wastegate?
And while i already have this page, i will ask my last question. Right after i go through reving out the car through lets say 2nd and 3rd, the rpms will drop down to 3000 rpms then stop and stay there. I have to tap the gas to get it to stop, then i will just daily drive and it will stay again above like 2500 rpms. It takes a minute for it to stop doing that. Is this an s300 problem?
Any questions for me, just ask. thanks a lot guys.
Old Apr 12, 2006 | 01:03 AM
EF-EF's Avatar
I have the same problem to with the 44mm wastegate...I'd like to know how someone fixed this problem...good thread..
Old Apr 12, 2006 | 02:31 AM
crucian's Avatar
Default Re: Over-boosting! Help!! (Makdaddynuge)
On the issue with the wastegate, I have the same problem with my 38mm Turbosmart. Haven't figured it out yet. On the idle issue, no that isn't a S300 issue. Could be a tuning issue. Check all you settings in the parameter window. Make sure there is no vaccum leak anywhere on your motor. Also, make sure that the throttle is not sticking. Check that nothing is getting caught up on your throttle plate lever.
Old Apr 12, 2006 | 03:49 AM
Blown90hatcH's Avatar
This might help:
https://honda-tech.com/zerothread?id=976704
Old Apr 12, 2006 | 04:11 AM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Makdaddynuge &raquo;</TD></TR><TR><TD CLASS="quote">References:
JDM gsr block
Any questions for me, just ask. thanks a lot guys. </TD></TR></TABLE>
check the throttle cable adjsutment and check for binding and sticking....if thats not it then turn down the idle air control duty cycle in the S300 software
Old Apr 12, 2006 | 03:47 PM
i still need some solutions to this boost problem. Would a boost controller help at all? Cause i am relying on the wastegate spring for my boost level.
Old Apr 12, 2006 | 04:57 PM
dohc-crx's Avatar
hey man this is chris with the white del sol that was down there last weekend. well in my kit i am using the small green and it is 7.25 but i have no idea why it jumped all the way to 10. when i first got tuned i had a big red spring and it cut me off at 5000 rpms at 10psi bc of hondata
Old Apr 12, 2006 | 05:03 PM
yeah i'm glad the hondata worked and cut me off at 10. I think i am going to try and tap my vaccum off t he compressor to see if that helps any. Also get a full exhaust put on because right now i am runing open downpipe, might have something to do with it.
Old Apr 12, 2006 | 05:23 PM
dohc-crx's Avatar
well i have mine tapped to the compressor and i havnt had a prb.
Old Apr 12, 2006 | 05:27 PM
dohc-crx's Avatar
Default Re: Over-boosting! Help!! (dohc-crx)
by the way i am not coming down this weekend but im prb coming the next weekend and i want to race u to see how i do against the better turbo kit on a lighter car
Old Apr 12, 2006 | 05:38 PM
sounds good, i should have it boosting better by then
Old Apr 14, 2006 | 02:06 PM
bump
Old Apr 14, 2006 | 03:25 PM
quicksilver1689's Avatar
i ♥ snails
Get a good vaccum source and make sure the spring isnt getting stuck.
Old Apr 19, 2006 | 12:00 PM
chris PM me your number to talk about friday
pcguy760
Jul 8, 2011 09:08 AM
adictionbass
Oct 15, 2005 10:18 AM
1 POINT 8
Jan 13, 2004 04:16 PM
Talon12bp
Nov 12, 2003 05:05 AM
Mikex25
Aug 30, 2001 01:28 AM
