Ordered sandwich plate for feed
Old Apr 24, 2013 | 05:03 PM
civicSIhatch93's Avatar
Icon2 Ordered sandwich plate for feed
So I ordered this sandwich plate from Jegs the other day and now that I actually am doing the research I notice not many people use them on HT. I want to run the oil feed line and also have a oil pressure gauge.
http://www.summitracing.com/parts/ear-514erl
http://www.jegs.com/i/Earls/361/514/10002/-1
Both inlet and outlet of this piece is 3/8". I'm not sure if that is the common measurement, but I was expecting NPT or AN compatability. My real question is, is this sandwich plate going to be futile since it might just be for an oil cooler?
On another note I do have a steel T instead of a brass one that I could use for the feed, but I've read that the possibility of it breaking is higher.
Old Apr 24, 2013 | 06:19 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: Ordered sandwich plate for feed
I can't answer the other question
I have a sandwich plate, been running it for quite some time. No issues here because I didn't want to tap off the oil pressure sensor
Old Apr 24, 2013 | 06:47 PM
Spawne32's Avatar
my sandwich plate bolt unscrews every time i take my filter off, quite annoying lol
Old Apr 24, 2013 | 07:03 PM
Khnemu's Avatar
Even using a socket to torque it down? I had that problem just hand tightening that bolt. Used a 27 mm socket (MFactory plate) to torque it down and haven't had a problem since.
Old Apr 24, 2013 | 07:13 PM
Spawne32's Avatar
what did you torque yours too, mishimoto never gave a torque spec for the bolt so i hand tightened it (pretty tight too)
Old Apr 24, 2013 | 07:33 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
That is because you have toothpick arms. Torque it down to about 5-10 ft lbs less than factory. You don't want to match factory specs or go above them for that matter as it strains the part to failure.
Old Apr 24, 2013 | 07:54 PM
Spawne32's Avatar
lol one day im going to get you in a headlock with my toothpick arms so that we can discuss the coke bottles i wear on my face to cover my crosseyes
Old Apr 24, 2013 | 07:57 PM
DO IT ON ALL FOURS
Hahaha!!! You would break this fragile old man? Geesh...
Old Apr 24, 2013 | 08:03 PM
Spawne32's Avatar
hey i might be short, but im italian.
Old Apr 24, 2013 | 08:06 PM
xile6's Avatar
I got a glow shift one. My blog started leaking and it was hard to find a replacement oring for it since it was double.
Bt the fittings on my are 1/8npt. The I got a 4an to 1/8npt to run my feed line.
3/8 sounds like coolant or oil filter relocation kit.
Old Apr 25, 2013 | 07:22 AM
Yeah that is what I was worried about. The others ive seen didnt have holes that big. It didnt say it in the description. Should I just get a glowshift or ge?
Old Apr 25, 2013 | 08:23 AM
4genaccordfreak's Avatar
There should be more than 1 option. Some sandwiches are specifically plumbed for external oil coolers, some for large oil lines and some for 1/8"NPT fittings for sensors/feed lines.
I am using a Golden Eagle sandwhich and I had a choice between 4 or 5 versions with a variety of fittings. Typically oil feed lines require a 1/8"NPT -> AN adaptor if you do not want to to "T" off the factory oil pressure sensor.
Looks like you purchased the incorrect sandwich for your setup.
Old Apr 25, 2013 | 08:49 AM
xile6's Avatar
Yea cancel that oil and get the glow shift.
It should be able $40 shipped. Look for coupons first. Retailmenot.com
I think mines was like $26 when I had a coupon code.
Old Apr 25, 2013 | 09:14 AM
DO IT ON ALL FOURS
The problem is a lot of the cheaper sandwich adapters feed unfiltered oil to those ports. There is a reason they are so cheap... Most people couldn't care less or are truly ignorant to that fact.
Old Apr 25, 2013 | 09:39 AM
ryguy2588's Avatar
I've used a glowshift one for a while now, and my o-ring broke too. They sell them on their eBay store for like $2.
Old Apr 25, 2013 | 10:18 AM
Muckman's Avatar
Moderator in Chief
The ITR engine oil cooler center bolt is torqued to 54 ft-lbs.
Old Apr 25, 2013 | 11:33 AM
Khnemu's Avatar
50 ft lbs. Never had a problem since.
Oh and for people that lose their orings, I found out you can go to Walmart or wherever they sell massive options of oil filters. You can pull the orings off of oil filters and test fit them on your sandwhich adapter. I found one that fit perfectly lol.
Old Apr 26, 2013 | 07:01 AM
If anyone wants to run an external oil cooler. Pm me. Im going to use the steel t with a brave stop it can't break. Probably an inline filter as well
Old Apr 26, 2013 | 07:05 AM
CaliforniaDad's Avatar
No-Traction = Fun
Mine does the same thing! So last go around I put a dab of thread sealer on the pc that's screws onto the factory orifice.
Old Apr 26, 2013 | 07:31 AM
kyden's Avatar
I have a golden eagle sandwich plate and it has never come off on its own.
Old Apr 26, 2013 | 09:52 AM
DO IT ON ALL FOURS
Most people WAY over torque their oil filter anyways. If you need a tool to take it off, you are either extremely weak or put it on WAY too tight...
Old Apr 26, 2013 | 11:17 AM
wantboost's Avatar
Who is Mr Robot?
I thought I saw you on Jersey Shore trololol :D
Old Apr 26, 2013 | 11:19 AM
Spawne32's Avatar
GTL everyday bro
Old Apr 26, 2013 | 11:22 AM
wantboost's Avatar
Who is Mr Robot?
I always put ny filters on hand tight but it seems that after repeated heat cycles it either work hardens to the threads or just shrinks lol. But I've always had this problem with the K24, even the LS7 on occasion.
Maybe I need to try a small dab of anti seize on the mount threads. We have to safety wire the filter on the LS7 due to track tech requirements (Road Atlanta and Atlanta Motorsports Park, as well as Barber)
Old Apr 26, 2013 | 11:23 AM
wantboost's Avatar
Who is Mr Robot?
GTL everyday bro
I knew it you little Guido
