OPinions on sludge in compressor housing?
Old Jun 30, 2003 | 08:32 AM
PM-Performance's Avatar
Default OPinions on sludge in compressor housing?
opnion needed, i took off my housing yesterday just for ***** and giggles. and i noticed i had like oil sludge caked up in the housing. i cleaned it up pretty good where i could get a rag to it, but im curious why ? does that mean my seals are bad? someone suggested too much oil pressure causing it to do that? i dunno , someone else told me its normal and not the seals unless its like dripping oil out of it . It doesnt smoke at all and only like 7 months old.
suggestions ?
Old Jun 30, 2003 | 08:43 AM
hybridb18's Avatar
Default Re: OPinions on sludge in compressor housing? (itr206)
mine does something similar to that, the sludge smells like burnt tire.
Old Jun 30, 2003 | 10:06 AM
Default Re: OPinions on sludge in compressor housing? (hybridb18)
BUMP.
Old Jun 30, 2003 | 10:31 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Hey pete, did u check any of your intercooler pipes for any oil ?
Old Jun 30, 2003 | 07:33 PM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">opnion needed, i took off my housing yesterday just for ***** and giggles. and i noticed i had like oil sludge caked up in the housing. i cleaned it up pretty good where i could get a rag to it, but im curious why ? does that mean my seals are bad? someone suggested too much oil pressure causing it to do that? i dunno , someone else told me its normal and not the seals unless its like dripping oil out of it . It doesnt smoke at all and only like 7 months old.
suggestions ?</TD></TR></TABLE>
Do you turbo time your car after driving it...?
Old Jul 1, 2003 | 03:16 AM
Default Re: OPinions on sludge in compressor housing? (SIXTYdashONE)
yea i checked the pipes and nothing really, the one directly fromt he turbo had a tiny bit of sludge in it, but my return line gasket was leaking right into the silicone coupler, so it mighta seeped in from there. . . i got everything sealed now, so i think im just gonna pop it back on and run it for a while and take it back apart and see.
yes i time it, at 1st when i didnt have the timer hokoed up , i would sit in the car for a short short time . now i set the timer to auto so it senses load and what not to determine the cooldown time .
someone else told me the pressure ffrom the feed line causing it ? and maybe to put some sort of thing in line to take the pressure down from the block ? i dunno how true that is though.
Old Jul 1, 2003 | 05:36 AM
Flamenco-T's Avatar
it's usually your seals.
stan
Old Jul 1, 2003 | 07:20 AM
Evil DOHC's Avatar
Default Re: OPinions on sludge in compressor housing? (Flamenco-T)
What size feed and return line are you using? I would suggest -3 or -4 for feed and -8 or -10 for return. I have seen this problem with people using small feeds and returns, where the oil either backs up or too much pressure is forced into the turbo.
EVIL
Old Jul 1, 2003 | 08:49 AM
Default Re: OPinions on sludge in compressor housing? (Evil DOHC)
the feed is -4 and the return is -10.
Old Jul 1, 2003 | 08:54 AM
Flamenco-T's Avatar
I can gurantee if you use a -3AN, the smudges will be reduced by significant amount. I had sold to many people here and I even used it on our race car. The seals are already wekened and we would get a lot of oil smudges after each run. I took the -4AN lines out and use my-3AN, and the housing stays clean for 3-4 runs before we see slight oil versus 1 run previously.
stan
ryguy2588
Jun 9, 2011 02:27 PM
zach1288
Mar 18, 2009 03:54 PM
riceball777
Feb 5, 2008 03:23 PM
done
Jul 27, 2004 08:10 AM
VanHonda
Nov 25, 2003 10:07 AM
