opinions on homemade boost controllers
Old Sep 14, 2005 | 10:00 AM
crx88fast's Avatar
Default opinions on homemade boost controllers
I ordered my boost controller today but its not going to be in this weekend so i was thinking about making one for the weekend... whats the bad side to this....if anyone has any experience with them good or bad let me know, but i really need to up the boost this weekend...
Old Sep 14, 2005 | 10:46 AM
AIminiS10's Avatar
Default Re: opinions on homemade boost controllers (crx88fast)
Just make sure you adjust it properly, do it in small increments, and watch the boost gauge. You can overboost real quick while adjusting them if you do it to much at a time. I ran one for a long time and never had a problem with it. Just don't go overboard with it or you will blow her up (not knowing what internals you have done to your car)!!!
Old Sep 14, 2005 | 11:08 AM
bubs's Avatar
I tried to make one the other day with plans from c-speed racing (http://www.c-speedracing.com/howto/mbc/mbc.php) and it didn't really work like I wanted it to..
It would boost to the amount I wanted it to, but it would also trap the pressure between the wastegate and the MBC when I shifted, which made the wastegate stick open. So, it would cause a ton of lag since the turbo wasn't getting enough exhaust gas to make it spool.
I'm probably going to work on it some more tonight to see if I can make a workaround.
Old Sep 14, 2005 | 11:51 PM
crx88fast's Avatar
Default Re: (bubs)
thats the design i was going to go with because of how simple it is.. i was just wondering if they are bad about creeping or anything like that.. or any other dangers that could come up..
Old Sep 15, 2005 | 01:09 AM
jDMJeRk's Avatar
Default Re: (crx88fast)
I just had a manual one put in mine for the time being to get tuned. From what I understand the controller tricks the waste gate to open. So instead of the boost leaving when it opens with a spring, it slowly allows it to open causing possible boost spikes.
Just slowly adjust it and keep an eye on the gauge.
builtboostedteg
Apr 5, 2006 05:19 PM
B_1_8_hatch
Oct 6, 2003 12:01 AM
Tru Dynamix
Sep 14, 2002 03:58 PM
Snafu-Si
Mar 5, 2002 02:07 AM
