OPINION: WHICH TURBO TO GO WITH?
Old Nov 13, 2003 | 04:18 PM
blumeany's Avatar
Default OPINION: WHICH TURBO TO GO WITH?
I am building my first turbo project. I plan on boosting a JDM B18C low boost 5-7 lbs. I am trying to decide whether to go with an internal wastegate or an external wastegate. Pros of internal wastegate, single downpipe, plenty of internal wastegate turbos to choose from. Better suited for low boost engine? Cons boost creep, less control.
External Wastegate pros, less boost creep, better tunability. Cons, additional cost for wastegate dumptube, clearance issues?
What do you guys think? Let me know.
Thanks in advace
Old Nov 13, 2003 | 04:21 PM
redboost10's Avatar
Default Re: OPINION: WHICH TURBO TO GO WITH? (blumeany)
wastegate dump tube isnt that much, just get the flange and weld it to a pipe thats about 6 inches long, going straight down
Old Nov 13, 2003 | 04:36 PM
Boltz's Avatar
internal gates are quieter and im sure they help restrict exhaust flow
external gates are loud if vented to astmosphere and help to free up some exhaust flow.
also external wg will tap off of the gases in the manifold, and the internal gate is built into the turbo to release the gas where the dp meets the turbo
Old Nov 13, 2003 | 05:21 PM
TeStUdO's Avatar
Well you want 5-7psi now, but I know you will want more later. I would go with an external wastegate for the versatility and its easily upgradeable
Old Nov 13, 2003 | 05:25 PM
RenoRacing's Avatar
Default Re: (TeStUdO)
I'd thow the extra $100-$250 upfront and leave you w/ more opportunites down the road. You'll want more,... then more,...then more! It's a terrible disease.!
Old Nov 14, 2003 | 09:44 AM
rollup!'s Avatar
internal if you know for sure your not going over 8psi. But Im goin too tell ya one thing. Evrybody will agree boost is like crack too a crackhead YOU"LL ALWAYS WANT MORE! so if I was you I would go external cause then theres always that option too go higher
dagle
Feb 9, 2008 12:51 PM
16vt
May 29, 2005 10:55 AM
nolovenodie
Nov 8, 2002 02:43 PM
yorktonite
Aug 20, 2002 04:37 AM
PolySquared
May 12, 2002 09:57 PM
