Open WG question??
Old Aug 15, 2006 | 02:58 PM
DrivinVtec's Avatar
Default Open WG question??
I just got a dump tube made an ive been hearing all these people saying it sounds loud an beastly when open. well mine doesnt. sounds normal to me. got any idea why that is???
Old Aug 15, 2006 | 03:05 PM
bb_one's Avatar
Default Re: Open WG question?? (DrivinVtec)
Is your wastegate opening? You should be able to tell the distinct difference in sounds.
For example...turbo spool, spool, then WAHHHHHHH (WG opening), type sound.
Old Aug 15, 2006 | 03:14 PM
DrivinVtec's Avatar
Default Re: Open WG question?? (bb_one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb_one &raquo;</TD></TR><TR><TD CLASS="quote">Is your wastegate opening? You should be able to tell the distinct difference in sounds.
For example...turbo spool, spool, then WAHHHHHHH (WG opening), type sound. </TD></TR></TABLE>nope..just the..just here the bov i think. it boost 7psi so it seems to be opening. but i shift at 4500rpm...right about when hit it hits full boost. maybe that why. maybe after i get it tuned an bring it up in rpms it will get louder.
Old Aug 15, 2006 | 04:54 PM
Zakar's Avatar
not smart to hit full boost untuned..
Old Aug 15, 2006 | 08:14 PM
DrivinVtec's Avatar
Default Re: (Zakar)
its safe map.
Old Aug 15, 2006 | 08:21 PM
EK k kay's Avatar
Default Re: (DrivinVtec)
A safe map is a tuned map.
But anyways. You should definitely hear a distinctly louder sound when the wastegate opens up. Are you sure it's opening up?
Old Aug 15, 2006 | 09:16 PM
DrivinVtec's Avatar
Default Re: (EK k kay)
if it wasnt opening up..wouldnt it boost more then 7psi?
Old Aug 15, 2006 | 09:25 PM
sp00led's Avatar
If the spring is &gt; 7psi then no at that rpm because I would think that a larger spring might cause it to not open that much yet. Before I only hit 4-5psi and it wasn't loud at all. If it is fully open you should definantly hear it. I finally tuned my car on 10psi (wastegate spring) and you could definantly tell. damn thing got loud as hell!
Old Aug 15, 2006 | 09:30 PM
DrivinVtec's Avatar
yeah..7psi spring. I do her a shhhhhhh noise if im in higher gear an hitting 7psi around 3-4k. is that it?? its not loud thow. i think maybe im not hitting high enough rpm to notice the noise level?? what u think?
TheOdd001
Mar 17, 2010 05:07 AM
JShull
Mar 12, 2008 10:24 AM
zbaber
Oct 9, 2005 02:50 PM
WhiteSTi
Sep 26, 2003 10:30 AM
