open vs. closed dumptube
Old Jul 25, 2004 | 02:57 PM
  #26
b16hybridsol's Avatar
Default Re: (patdemps)
theres a topic going around about using screens, you just use a big Q-clamp, cut a piece of screen(or 2 like i use) then push it over the intake and tighten the Q-clamp around it. as for the loudness, once i get sick of it i'l prly put a lawnmower muffler inline witht the dump tube, but for now, it stays
Old Jul 25, 2004 | 07:19 PM
  #27
Bailhatch's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I've never heard any loud nasty sounds at full boost. I run no filter [only screen] so maybe the loud *** turbo is covering the sound of the dump? I don't re-route my dump into my exhaust, but I have a dump tube that is about 24" - 30" long.</TD></TR></TABLE>
thats weird. i thought my friend was the only one. I put a revhard kit on his b18b and you can't hear when it opens at all. I did 2 external dumps in the last couple weeks and both are extremely distinct and loud when they open. Confusing, but as long as it works fine who cares
Old Jul 25, 2004 | 09:48 PM
  #28
blackeg's Avatar
Default Re: (Bailhatch)
i also was running the screen instead of filter. i doubled it over and i find it hard to believe that any particle of substance would make it into the turbo.
a little off topic, but one of my friends is running an open dump on his car(vr6) and its quite possibly the loudest thing ive ever heard. he gets on it and people a half mile away are looking around like what the **** was that??!
Old Jul 25, 2004 | 10:11 PM
  #29
ForcedEk9's Avatar
Default Re: (blackeg)
My damn dumptube blew off on the dyno. Don't ask how, I'm as clueless as you all.
Old Jul 25, 2004 | 10:14 PM
  #30
ForcedEk9's Avatar
Default Re: (ForcedEk9)
yep, definitely loud. Louder now that I've got no tube.
Old Jul 25, 2004 | 11:22 PM
  #31
wongf22b2's Avatar
I'm kinda new to this does anyone have a write up on the difference between open and closed wg? What's the point of rerouting "un-needed" air into the system in a closed setup?
Old Jul 26, 2004 | 06:24 AM
  #32
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (wongf22b2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wongf22b2 &raquo;</TD></TR><TR><TD CLASS="quote">I'm kinda new to this does anyone have a write up on the difference between open and closed wg? What's the point of rerouting "un-needed" air into the system in a closed setup?</TD></TR></TABLE>
As you know, the wastegate controls the flow of exhaust gasses [not just "un-needed air"] through the turbine. In some if not most states, it is illegal to have an open dump tube because you are simply venting raw exhaust gasses to the atmosphere. In a closed system, you re-enter the gasses that have flowed through the wastegate back into the main exhaust system downstream of the turbo. This allows the gasses that have passed through the wastegate [and essentially around the turbo] to still pass through the catalytic converter as well as the rest of the exhaust system. This is undesirable to some people, because it is thought that unless you have a very shallow [low angle] re-entry into the main exhaust stream, you are hindering the flow of exhaust and therefore causing backpressure, thus robbing horsepower. I run an open dump because making a closed dump system would have been hell. I run no catalytic converter as it is, so having a closed dump for the sake of the environment would do no good. If you do run an open dump, you should still have some sort of tube to direct the gasses out of the engine bay, or a number of bad things can happen [melting hoses, overheating radiator, sucking raw exhaust into compressor, etc.].
  #33
Raunch's Avatar
Open here ........... The look on ppls face when you drive by them @ open wastegate is priceless ...... Just love it
Old Jul 26, 2004 | 06:46 AM
  #34
ShapeGSX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">
im thinking about ditching my filter and throwing a screen on my turbo so I can hear it more over the open wastegate. i love the sound however, id like to quiet it up just a bit and i want to hear the turbo more. plus i hear quite a few guys are running a screen....i just need to get a bit more info on how to mount it on the turbo, etc before i do it.</TD></TR></TABLE>
A screen is a lot more restrictive than an air filter.
Old Jul 27, 2004 | 05:57 AM
  #35
wongf22b2's Avatar
Default Re: (DaX)
As you know, the wastegate controls the flow of exhaust gasses [not just "un-needed air"] through the turbine. In some if not most states, it is illegal to have an open dump tube because you are simply venting raw exhaust gasses to the atmosphere. In a closed system, you re-enter the gasses that have flowed through the wastegate back into the main exhaust system downstream of the turbo. This allows the gasses that have passed through the wastegate [and essentially around the turbo] to still pass through the catalytic converter as well as the rest of the exhaust system. This is undesirable to some people, because it is thought that unless you have a very shallow [low angle] re-entry into the main exhaust stream, you are hindering the flow of exhaust and therefore causing backpressure, thus robbing horsepower. I run an open dump because making a closed dump system would have been hell. I run no catalytic converter as it is, so having a closed dump for the sake of the environment would do no good. If you do run an open dump, you should still have some sort of tube to direct the gasses out of the engine bay, or a number of bad things can happen [melting hoses, overheating radiator, sucking raw exhaust into compressor, etc.].</TD></TR></TABLE>
Thanks for clearing that up, well explained. So it's basically for environmental issues... so people with open set-up's... how do they pass inspections etc.. etc.. or maybe they just don't pass them technically and pay the mechanic?
Old Jul 27, 2004 | 06:36 AM
  #36
DaX's Avatar
DaX
Loved
Community Favorite
Some states and locations don't require cars to be inspected. I live in GA, where parts are non-inspection...but where I live, all I have to do is pass an emission test. I don't have a Ref looking through my car to see what is and isn't legal. Honestly, I don't think most Emission Testers could tell a turbo from fuel filter.
It does help to know someone though...that's how some people I know pass without a catalytic converter.
Old Jul 28, 2004 | 02:50 PM
  #37
RyanEJ8's Avatar
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">I have open dump love it ******* makes the car sound mean. V8 guys here are like WTF when my 4 door is raping there cars lol.
There was a post on here a while ago this guy did a test and it was like 15-18hp gain with open dump on his loud.</TD></TR></TABLE>
Anyone have a link to this? I did a search on dumptube and couldn't find it.
Old Jul 28, 2004 | 09:07 PM
  #38
DaX's Avatar
DaX
Loved
Community Favorite
Are you sure it wasn't open downpipe and not open dump?
Old Jul 28, 2004 | 09:26 PM
  #39
adictionbass's Avatar
Default Re: (DaX)
This might be off topic, but are there any guys running 400+ whp that can pass a sniffer test?
Old Jul 28, 2004 | 09:56 PM
  #40
RyanEJ8's Avatar
Default Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">This might be off topic, but are there any guys running 400+ whp that can pass a sniffer test?</TD></TR></TABLE>
Not likely on a 1.6-1.8 liter Honda.
Old Jul 28, 2004 | 11:29 PM
  #41
DaX's Avatar
DaX
Loved
Community Favorite
Just the sniffer? I don't think horsepower is a factor...if you have a good tune [i.e. - good AFR out of boost] you should be fine. The only way I think it could be a factor is that most high HP applications don't run a cat.
Old Jul 28, 2004 | 11:36 PM
  #42
shermanyang's Avatar
shietz...if MN ever got back into doing the sniffer testing...i'd slap on my stock injectors, 3" cat, stock exhaust and use my EMS to tune a/f to pass the sniffer.
Old Jul 28, 2004 | 11:38 PM
  #43
Kwuaymaikrup's Avatar
I will let you know. I am going to try tomorrow morning. All 55 inches of my exhaust. I talked to a guy down at the emmisions place and told him about my car (my exhaust dumps right under the shifter) and he told me to bring a piece of flex to temporarily route the exhaust out the side of my car so they could get the sniffer in it. I also told them I didn't want anyone driving my car on the rollers due to the Tilton twin disk. He told me just to tell the tester and they will test my car without the rollers, this should help emissions a bit seeing as no load will be on the engine.
-Ryan
B20-T
Feb 18, 2003 01:05 PM
falcongsr
Jan 12, 2003 12:58 AM
Timmayeg
Dec 12, 2002 09:47 PM
Quick 200k Mile Motor
Nov 10, 2002 03:08 PM
bgod
Aug 13, 2001 09:43 PM
