Open Loop and Closed Loop conditions
Old Mar 6, 2004 | 06:47 AM
mrx's Avatar
mrx
Default Open Loop and Closed Loop conditions
Hallo,
can anyone tell me on what sensor conditions the honda ecu decides to make open loop or closed loop?
i think mainly throttle position and MAP is responsible for this, maybe a bit the rpm too but i think thats not much.
i wan't to know: at xx% throttle the ecu runs Openloop or at xx mbar MAP the ecu runs Openloop or simething
Thanks
Malte.
Old Mar 6, 2004 | 08:14 AM
hondaapi's Avatar
Default Re: Open Loop and Closed Loop conditions (mrx)
Ziemlich klein die Welt :-)
Hoffe du bist wegen dem Stecker nicht sauer?
Old Mar 6, 2004 | 09:01 AM
InfamousGSR's Avatar
Default Re: Open Loop and Closed Loop conditions (hondaapi)
english? since this is an americam forum and all.
Old Mar 6, 2004 | 09:09 AM
Bontke's Avatar
Default Re: Open Loop and Closed Loop conditions (InfamousGSR)
From what I understand, the coolant temp sensor for the ECU decides the open closed loop opperation when you first start the car. After its warmed up, its in closed loop reading from the o2 sensor. When you floor the car and it sees a WOT from the TPS, the ECU reads a preset map and ignores the 02 sensor. As far as I know, open/closed loop only applies to the temp of the engine and it reads preset maps when its floored. Under normal driving it uses the o2 sensor to calculate the cleanest A/F ratio for the environment.
tdub1904
Nov 2, 2009 07:32 AM
otakueric
Sep 13, 2005 04:49 PM
Hoodwinked
Dec 1, 2003 12:13 PM
7rrivera7
Nov 21, 2002 09:43 AM
ckkl
Mar 10, 2002 03:44 AM
