Open dump tube vs. closed?
Old Apr 23, 2011 | 05:35 PM
jdmteg1728's Avatar
Post Open dump tube vs. closed?
im in the market for a new manifold/dp and dont really know which is better. i have a closed dump tube right now. id just like to know everyones opinion on the topic . what are the main differences etc. thanks
Old Apr 23, 2011 | 08:05 PM
boostedBLUfg2's Avatar
Default Re: Open dump tube vs. closed?
i've heard that open dump is good for a few more ponies up top, which would make sense. the only cons that i know of are the sound and the dumping of raw exhaust into the air (which doesn't really make any diff if you're cat-less)
Old Apr 23, 2011 | 09:29 PM
TheShodan's Avatar
Moderator
it makes a ton of difference than even not using a Cat-less.. But otherwise, that's about right.
Old Apr 24, 2011 | 10:15 AM
LS AzZkIkr's Avatar
I have been looking into doing this as well and I haven't found much info beside you may loose power but barely noticeable. Shodan can you confirm? I have also read that if you are to do this that you want to recirculate it about 18" or more downstream of the turbo. Just wondering if it will cause much turbulence even with a 3" dp and exhaust.
Old Apr 24, 2011 | 01:48 PM
th3pwn3r's Avatar
Could you please clarify this? I was trying to understand but your post wasn't all that clear.
Old Apr 24, 2011 | 02:03 PM
JDMCRX's Avatar
If you do a search there is a good thread on this done years ago. You do loose power. An external wastegate can control a bigger turbo better.
Old Apr 25, 2011 | 07:46 AM
RealStreet's Avatar
Honestly, from a person with a dumped wastegate, the power isn't worth the sound. If you want your car to sound ridiculously loud under WOT then it's for you, but if you want a car that is more discreet, I would forgo the dumped wastegate.
Old Apr 25, 2011 | 08:17 AM
sanman000719's Avatar
man my crx on open dump isnt any louder than a harley at wot
most think thats ok because its a harley, but i think my 600+h.p. honda sounds better
Old Apr 25, 2011 | 10:15 AM
lsturbo33's Avatar
If your running open dump on low boost the gate cracks open more often and sounds like ***. If it were me low boost mild setup-recirculate Higher boost levels-dump.
Old Apr 25, 2011 | 12:43 PM
redline1219's Avatar
Im running high boost and am using a closed dump. I dont really like the sound of the wastegate open, it sounds worse than a Harley. Plus I like the fact that its a little more sleeper-ish, thats also why I coated the intercooler black and didnt cut my bumper out... But thats just my opinion.
Old Apr 25, 2011 | 01:32 PM
LS AzZkIkr's Avatar
Has anyone done back to back comparison or any comparison what so ever? A friend of mine has an Integra that has 2.5" dp and exhaust with a recirculating dump tube and it will not boost above 16psi. I think this is more to do with the size of his exhaust more than his dump tube. How much of a restriction is this with a 3" exhaust?
Old Apr 25, 2011 | 01:43 PM
wild because my gsr open dump, and downpipe only is pretty dam quiet or its because i dont drive light to light like im a mad man maybe (self discipline).
Old Apr 25, 2011 | 06:56 PM
justin.parker's Avatar
That's strange. Mine is 3" all the way and I hit 20psi no problems.
Old Apr 25, 2011 | 07:02 PM
gtownv6's Avatar
open dump on low boost sounds like crap
Old Apr 25, 2011 | 08:03 PM
crispchris's Avatar
my closed loop dumptube on low boost sounded great I thought....If your car is a daily driver I would strongly recommend a closed loop dumptube.
Old Apr 25, 2011 | 09:15 PM
joppe's Avatar
Dont use low boost
Here is test my old zc, turbo was not boosting (broken) and i was testing if wastegate is working.
http://www.youtube.com/watch?v=5mlBwees4ps
Old Apr 26, 2011 | 02:29 AM
wanna be quiet then use a closed loop dump and a cat with a resonator and what ver else you can do to keep it quiet while choking the turbo out not allowing it to breath the way it needs to I mean in the end it is what ever you want.
op asked the differance and its obviouselt power potential like most of us know it is.
arc_55
Welding / Fabrication
Aug 1, 2009 05:36 PM
Hobkins
Apr 12, 2009 09:33 PM
boostjunkie757
Dec 30, 2004 09:19 AM
turbo se
Apr 7, 2003 04:33 PM
brownman72000
Jul 25, 2002 03:32 PM
