open downpipe....question.
Old May 12, 2004 | 10:24 AM
patdemps's Avatar
Default open downpipe....question.
Well my car will be done in a few hours. Then, Im taking it home from college. I have to get my flex pipe welded onto the downpipe and get it all fitted correctly. However, by the time i get the car done and started up all the exhaust shops will be closed. But I have the downpipe bolted up, its just a few inches or so short of the cat (where the flex pipe is going). I can bring the flex pipe with me home tonight and get an exhaust shop to do all the work in the morning (about an hour or so drive to my house...60 miles). Now running open downpipe...is that safe to drive that far? Im sure its going to be loud...but how loud?
anything else I should know? thanks guys.
Old May 12, 2004 | 10:29 AM
RobbieG35's Avatar
12 Years Strong
Default Re: open downpipe....question. (patdemps)
Its not really that loud, not near as loud as open header or something like that. Plus if its close to your cat some of the exhaust will actually be going through the b-pipe and rear section
Old May 12, 2004 | 10:32 AM
RotiEatter's Avatar
Ditto
Default Re: open downpipe....question. (HybridHatch88)
Open DP isn't too loud, you'll be alright.
Old May 12, 2004 | 10:33 AM
patdemps's Avatar
Default Re: open downpipe....question. (RotiEatter)
thanks for the quick info fella's....
shouldn't harm any power should it? Im assuming no...just making sure.
Old May 12, 2004 | 10:37 AM
TRE_'s Avatar
i ran open downpipe for a few months... its really not that bad. only time it bothered me was when i drove for 2 hours on the highway... the gas fumes get to you after a while.
but i know people that run open downpipe constantly with no problems so you'll be alright
Old May 12, 2004 | 10:40 AM
SleepyEG's Avatar
Default Re: open downpipe....question. (THE_HX)
Just something to think about, this is the same as people running E-cutouts, which happens all the time. There is no reason to worry about this.
Old May 12, 2004 | 10:42 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE_HX &raquo;</TD></TR><TR><TD CLASS="quote">i ran open downpipe for a few months... its really not that bad. only time it bothered me was when i drove for 2 hours on the highway... the gas fumes get to you after a while.
but i know people that run open downpipe constantly with no problems so you'll be alright</TD></TR></TABLE>
Yea i can vouch for that, you will get out smellin like gas
Old May 12, 2004 | 10:47 AM
SOHC_MShue's Avatar
i don't know about you guys, but my car is open dp right now and extremely loud.
Old May 12, 2004 | 10:52 AM
TurboBumblBee's Avatar
Default Re: open downpipe....question. (SOHC_MShue)
i ran my old setup which was an NA setup and it was EXTREAMLY load w/ an open dc sport header... i noticed that since installing the turbo the exhaust is actually quieter so that leads me to belive that open downpipe will be quieter then open header!
Old May 12, 2004 | 10:54 AM
RobbieG35's Avatar
12 Years Strong
Default Re: open downpipe....question. (Boostfedb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">i ran my old setup which was an NA setup and it was EXTREAMLY load w/ an open dc sport header... i noticed that since installing the turbo the exhaust is actually quieter so that leads me to belive that open downpipe will be quieter then open header!</TD></TR></TABLE>
I switched from a stock manifold (open header) to a DC JDM 4-1 for ***** and giggles until the turbo stuff goes on and its 100% louder. It is sooo much louder than all my friends open DP boosted cars
Old May 12, 2004 | 11:11 AM
turboH22Aakkord's Avatar
hahaha Amen to the gas fumes!!!
Old May 12, 2004 | 11:14 AM
patdemps's Avatar
Default Re: open downpipe....question. (turboH22Aakkord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote">hahaha Amen to the gas fumes!!! </TD></TR></TABLE>
hopefully its not too bad. i hate the smell of gas.
Old May 12, 2004 | 11:32 AM
TRE_'s Avatar
its not that bad if you have the windows down and ****. the only reason i put the exhaust back on was because it was starting to get cold, and having the heater on and the windows up with open downpipe sucked.
Old May 12, 2004 | 11:42 AM
CheezeFrog's Avatar
I ran an open down pipe ... actually just a short 8" section of pipe shooting straight toward the ground. It's a little loud, but the turbo whine is pretty nice. Cars that are directly behind you, with their windows rolled up, won't even be able to hear your car. With their windows rolled down, they'll be sorta be able to hear you -- it's really not as bad as you'd think.
Old May 12, 2004 | 11:52 AM
bread's Avatar
I was in the same situation as you were and had to run open downpipe for a day. It's not incredibly loud (Harley loud) but more of a low rumble then anything. I actually liked the sound of it, mainly because you could hear the turbo whine like nobody's business.
You'll be fine, just enjoy it ...and be sure to keep your windows down.
Old May 12, 2004 | 01:40 PM
Rod.'s Avatar
Default Re: (bread)
I kind of like the sound of open downpipe especially when the turbo spools
Old May 12, 2004 | 03:20 PM
Ls-Rturbo's Avatar
Default Re: (redturbocivic)
enjoy it why you got it becuse your car will probley be a little slower once you put the exhaust back on.
Old May 12, 2004 | 04:18 PM
Meet07's Avatar
Default Re: (bl18t)
what about backfires. when i had my dp pointing straight at the ground it back fired alot and it end up breaking my turbine shaft in half???
Old May 12, 2004 | 05:01 PM
Deluzional's Avatar
Default Re: (Meet07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meet07 &raquo;</TD></TR><TR><TD CLASS="quote">what about backfires. when i had my dp pointing straight at the ground it back fired alot and it end up breaking my turbine shaft in half???</TD></TR></TABLE>
Never heard of that before, you must have been running super rich, I ran open downpipe for a few weeks, it was awesome. I had it worst than all of you, I had a cel so the fumes in my cabin made my eyes tear
Old May 12, 2004 | 05:19 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: open downpipe....question. (CheezeFrog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">I ran an open down pipe ... actually just a short 8" section of pipe shooting straight toward the ground. It's a little loud, but the turbo whine is pretty nice. Cars that are directly behind you, with their windows rolled up, won't even be able to hear your car. With their windows rolled down, they'll be sorta be able to hear you -- it's really not as bad as you'd think. </TD></TR></TABLE>
LOL this brings back memories. I ran open DP on my boosted BB1 and when the WG opened up the car sounded like a jet from outside the car. It was awesome
Old May 12, 2004 | 05:28 PM
slowsi00's Avatar
open downpipe is really the only way to rock a turbo car.
Blacknight117
Oct 18, 2011 12:58 PM
Ill Mitch
Jun 5, 2007 08:08 PM
the.hamburglar
Feb 18, 2007 06:32 AM
touge_dorifuto
Jul 24, 2005 08:06 PM
smokin rubber
Oct 11, 2001 10:27 AM
