Which One Is Easier To Use ????
Old Jan 16, 2009 | 07:39 AM
shotime's Avatar
Icon2 Which One Is Easier To Use ????
Real simple question for those with experience. As far as boost controllers go I had my mind set on the apexi avc-r and im getting the hondata s300. The s300 has a boost control option now would it be easier to use the boost control option in the hondata s300 OR would it better for me to use the apexi avc-r. They both can boost by gear which draws me to them but im not sure what way to go....... help please thanks
Old Jan 16, 2009 | 07:44 AM
dpetro1's Avatar
Default Re: Which One Is Easier To Use ????
if you already have s300 i think its easier and cheaper to just use that instead of having an extra unit/screen to play with. i guess the only downfall is that you need the laptop to make changes to s300 but im sure once you dial it it you wont need to make changes on the fly. also s300 basically uses the honda ecu and sensors rather than aftermarket pieces.
ive never used the avc-r but i know people that swear by it. i do use the boost by gear with s300 and have no complaints
Old Jan 16, 2009 | 07:48 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
The hondata boost by gear solenoid. simple cheap and you control it within hondata.
Im not sure how much that bost controller cost but im sure it's not as cheap as the Mac solenoid(hondata)
Old Jan 16, 2009 | 12:44 PM
HiProfile's Avatar
ECU-based FTW. S300 allows you to have 2 different settings, so you get it tuned for your max PSI, then have them set each gear's boost level for least wheel spin. Then have a higher or lower settings, for wet conditions or for slicks.
You can do that after going through hoops on the standalone, but I prefer to get it set beforehand and simply flip a switch.
Old Jan 16, 2009 | 02:33 PM
97hb's Avatar
I had avcr and it worked pretty good. Going to s300 with gear based/ rpm based boost control. It also has launch control with anti lag
Pompiuses
Dec 30, 2009 12:36 PM
jpo20
Apr 8, 2009 08:43 AM
CTR_B
Jun 12, 2008 11:10 AM
THEDirtyDseriesWOOT
Jun 26, 2007 11:40 AM
