OK to run BOV pressure source directly off Intake Manifold?
I have my map sensor directly off the IM, I have my WG directly off the IM, is it ok to run the BOV directly off the IM as well? I was thinking about just tapping a fitting onto the IM and run a hose from that.
Re: OK to run BOV pressure source directly off Intake Manifold? (clip the apex)
Yep that's fine. You can run all of your vacuum sources directly off the IM if you have the nipples. Like on the back of the Edelbrock IM. Those are sweet.
I ran all my vacuum lines threw the back of my edelbrock IM. Works great.
Re: OK to run BOV pressure source directly off Intake Manifold? (SpdFrk)
your bov will get a better signal as well running it directly to the IM rather than teeing it off other sources..
stan
stan
Re: OK to run BOV pressure source directly off Intake Manifold? (Flamenco-T)
thats exactly why I want to tap into my IM for all my sources.
