ok im stumped.....
Old Jul 28, 2002 | 04:54 PM
PROFILES2000's Avatar
Default ok im stumped.....
ok i just built my motor je10-1 b18c1 gsr. basicly today was D-day and well it failed. misrably.......i got a code 9 and it sounds like the car is somewhat missfireing. i found one unplugged clip it was the exact same as the intake air temp clip. im confuzed. im gunna try checking the rotor and cap tomarrow as for tontie well im to pissed off to work on that thing anymore. thanks
Old Jul 28, 2002 | 04:55 PM
PrecisionH23a's Avatar
Default Re: ok im stumped..... (PROFILEGSR)
code 9 is the crank angle position sensor i believe, ckp or some **** i cant remember. anyways, i had that happen on a car i worked on, replaced the distributor and the code went away.
Old Jul 28, 2002 | 05:05 PM
flip1199's Avatar
Default Re: ok im stumped..... (GudeH23a)
9 No. 1 Cylinder Position – Bad circuit or unplugged/defective sensor (not valid for throttle body injection engines or V6 Accords)
Old Jul 28, 2002 | 05:14 PM
Default Re: ok im stumped..... (flip1199)
would someone happen to have a picture of where it should be pluged into?
b\c i do have one clip left unplugged noooooo clue on to where it goes
Old Jul 28, 2002 | 05:17 PM
yea thats it, i confused the codes. it happened on my b18c5 block and b16a head, once we replaced the dist everything ran fine
Old Jul 28, 2002 | 05:27 PM
BoostinDC2's Avatar
there should be a clip by the crank
Old Jul 28, 2002 | 10:43 PM
Default Re: ok im stumped..... (BoostinDC2)
if you are refering to the crank angle sensor that is plugged in
Old Jul 28, 2002 | 10:51 PM
boostaholic's Avatar
yes, the crank angle sensor is down by the crank pulley. It's the only plug located down there that's on the block.
Old Jul 29, 2002 | 12:33 AM
Default Re: ok im stumped..... (boostaholic)
im gunna take a pic of the harness clip that i cant seem to find a place for it tomarrow when i go back out there to work on it. i needed a break from it.
Old Jul 29, 2002 | 06:37 AM
EE_Chris's Avatar
The sensors inside the distributor are: [at least for the 96-99 Civ's and 98-00 Teg's]
CYL = cylinder posistion
TDC = obvious
CKP = crank posistion
When OBD-II was introduced, they added a CKF sensor...the crankshaft fluctuation sensor. It was used to help determine when a mis-fire was happening.
Code 9 is for the CYL sensor which is located in the distributor.
[Modified by EE_Chris, 3:42 PM 7/29/2002]
DaveSi677
Nov 6, 2006 08:50 AM
ilovemyb16a
Sep 19, 2006 05:07 PM
jdmazm
Apr 24, 2005 04:34 PM
RaIn
Apr 20, 2003 08:05 PM
