Is it ok to boost on 9.8:1 compression stock motor??
Its not a honda motor....
Max I can run is 7 psi right???
Re: Is it ok to boost on 9.8:1 compression stock motor?? (1320me)
You can run as much as the motor will let you. Theres no limit. According to the info i found, y7 bottom end y8 top i was at 9.96:1 last year, and i boosted 15 psi. Just make sure everything is good, or get a good tuner to do it for you, no detonation.
Re: Is it ok to boost on 9.8:1 compression stock motor?? (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">You can run as much as the motor will let you. Theres no limit. According to the info i found, y7 bottom end y8 top i was at 9.96:1 last year, and i boosted 15 psi. Just make sure everything is good, or get a good tuner to do it for you, no detonation.</TD></TR></TABLE>
MarkAngelo
09-16-2004 10:39 PM
