Oil Weights?
Old May 15, 2009 | 09:22 AM
CTR_B's Avatar
Default Oil Weights?
What weight is the best to run?
I just had my HG replaced and I noticed on the receipt it said 5w30, And that just seems a little thin of and oil to run with an application that creates so much heat.
Also when I had my HG replace I had my test pipe installed and now I notice some smoke at full spool followed by a burnt oil smell. I check my piping for oil and TB with no signs. I also took off the DP with no signs as well.
Old May 15, 2009 | 12:16 PM
Topdawgg's Avatar
Default Re: Oil Weights?
Ive always ran 10w30 Mobil 1 or Quakerstate
320whp street tune, 1 year
447whp pump gas/493 whp race gas - 2 years
Going for 600+ this year, dont plan on changing
Never had ANY issues..
Old May 19, 2009 | 05:44 AM
CTR_B's Avatar
Thanks
Old May 19, 2009 | 09:16 AM
jdmdc529's Avatar
rotella 15w-40
Old May 19, 2009 | 10:01 AM
non-VTEC's Avatar
5w40 or 10w40 will work great on a turbo setup....
I'm currently running castrol syntec 5w50.....great oil pressure even when extremely hot......it maybe a little to thick but works well.
Old May 19, 2009 | 07:02 PM
Tjabo's Avatar
Originally Posted by jdmdc529
rotella 15w-40
I just switched over to that from the Rotella synthetic 5w40, and the 15w40 definitely gives a bit more oil pressure as expected. Seems pretty stable from cold to hot too.
Old May 22, 2009 | 07:06 AM
CTR_B's Avatar
I was told I should run a 20w50 or straight 50w?
Also should I be using a restrictor with a AR .62?
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
TomTomTuning
Honda S2000
32
Jul 5, 2006 06:16 AM
arjusmc
Honda Motorcycles
Jul 15, 2005 09:55 PM
RAB
Dec 23, 2002 08:56 AM
sushibug
May 30, 2002 10:43 AM
