Oil on spark plug need some info.
Old Feb 7, 2002 | 10:54 AM
Herminator's Avatar
Default Oil on spark plug need some info.
I was doing a compression test yesterday and found one of my plugs was coverd in oil. The compresion test came out good. cylinders 4 3 2 1 compresion 170, 180, 170, 170
Could my ringlandings be shot and the excess oil making the seal make my compresion test seem ok?
Old Feb 7, 2002 | 10:56 AM
dustin's Avatar
Default Re: Oil on spark plug need some info. (Herminator)
Was their oil on the porcelain? Many times the O rings at the top of the spark plug chamber leak and fill the bottom with oil.. when you unthread the plug it covers the plug in oil...
Dustin
Old Feb 7, 2002 | 10:57 AM
Rob03Pro5's Avatar
It could also be oil leaking from the valve cover.. making its way into the plug holes.. and then coating the tips as you remove the plugs. Or it could also be bad/leaking valve seals. What motor do you have? What is your compression (ex: 9.1:0)?
Rob03Pro5's Avatar
Default Re: Oil on spark plug need some info. (Rob92SC)
Damnit.. you're so much faster Dustin.
Old Feb 7, 2002 | 12:31 PM
Herminator's Avatar
I'll double check this weekend after I boost some more today and tommorow then do the compression check again. But as for as oil comming from the valve cover it maybe so, I noticed some oil in the bottom surrounding the spark plug hole to the head. My ride is a 2000 cebic Si 1.6 B16a2 9.1:1 SRP pistons with Greddy kit.
[Modified by Herminator, 9:32 PM 2/7/2002]
superslow-oto
Jul 7, 2008 06:52 PM
blackeg
Dec 29, 2004 05:30 AM
B18CRacer
Jul 14, 2004 05:06 PM
KekeK-18
Aug 15, 2001 05:16 PM
