oil sandwich adapter
i got an oil sandwich adapter and i put my stealthline 1/8th fitting in and it screwed in about two times, so it sticks out quite a bit. i was wondering if i need a non tapered fitting for this.....let me know, thanks
hey wat brand is ur b/c i need to get one thanks
Re: oil sandwich adapter (aryiman98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aryiman98civic »</TD></TR><TR><TD CLASS="quote">i got an oil sandwich adapter and i put my stealthline 1/8th fitting in and it screwed in about two times, so it sticks out quite a bit. i was wondering if i need a non tapered fitting for this.....let me know, thanks</TD></TR></TABLE>
Usually the 1/8 NPT fitting that goes into the plate is non tapered/flared...just straight |
Re: oil sandwich adapter (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost4life »</TD></TR><TR><TD CLASS="quote">hey wat brand is ur b/c i need to get one thanks</TD></TR></TABLE>
Funtion7 is a good brand https://honda-tech.com/forums/images/smilies/emthup.gif |
Maybe you should have checked what threads were on that sandwich before you screwed in a tapered pipe thread fitting. http://images.honda-tech.com/set1//smile/emcrook.gif Pipe threads usually engage 3+ threads to seal, so maybe its not tight enough. As long as it doesn't leak a bit, then its fine.
http://acautotechnic.bnetsoftw...TCode=
that is where i got mine from, ill tell ya in about a week and a half how easy it is to install |
Re: (aryiman98civic)
i have a brand new ac autotechnic oil sandwhich for sale $50 shipped pm me
i also use the ac autotechnic one i prefure this one because it has 4 1/8 npt ports which is perfect. i use all for ports 1 for turbo oil feed 2 for lsvtec oil feel 3 oil pressor sender 4 oil temp sender heres a pic https://i28.photobucket.com/albums/c...r/CIMG0104.jpg oil feeds on the left side and huge oil pressure sender on the bottom you can see this but the oil temp sender in at the top https://i28.photobucket.com/albums/c...r/CIMG0112.jpg Modified by riceball777 at 4:36 AM 11/20/2006 |
Re: (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">i have a brand new ac autotechnic oil sandwhich for sale $50 shipped pm me
i also use the ac autotechnic one i prefure this one because it has 4 1/8 npt ports which is perfect. i use all for ports 1 for turbo oil feed 2 for lsvtec oil feel 3 oil pressor sender 4 oil temp sender heres a pic https://i28.photobucket.com/albums/c...r/CIMG0104.jpg oil feeds on the left side and huge oil pressure sender on the bottom you can see this but the oil temp sender in at the top </TD></TR></TABLE> PM"d ya |
