oil return on the sidewinder
Old May 1, 2004 | 06:58 AM
93dx--hatch's Avatar
Default oil return on the sidewinder
What do you think of my oil return, I know I need clamps on the rubber hose, I had to make it in between my downpipe and dumptube.
I also pluged my water lines, one end with a bolt the other with a vacuum cap, will this be ok?
Trying to get this thing running today,
Old May 1, 2004 | 07:52 AM
Sohc Driver's Avatar
Default Re: oil return on the sidewinder (93dx--hatch)
can't see **** because the pics are too big. Try to get them resized. A good way would be hosting the pics on http://www.cardomain.com. They automatically resize the pics for you.
Khoi
Old May 1, 2004 | 07:54 AM
phatrick2332's Avatar
i kno im going to sound like an idiot, but im an NA guy..lol
The big brass fitting on the turbo is oil feed right? and then the big line with the flange is the oil return?
Im going boost, and i just wanted to be sure..
Old May 1, 2004 | 03:42 PM
Derek14's Avatar
Default Re: oil return on the sidewinder (Sohc Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">can't see **** because the pics are too big.
Khoi</TD></TR></TABLE>
Where's that Star Trek picture when you need it?
Old May 1, 2004 | 04:26 PM
TRE_'s Avatar
Default Re: oil return on the sidewinder (Derek14)
resized these bitches for you... they arejust hosted on my server right now....
Old May 1, 2004 | 07:25 PM
kcjohnnyboy's Avatar
Default Re: oil return on the sidewinder (THE_HX)
thats one weird return line..get one from stan (flamenco-t)
Old May 1, 2004 | 10:26 PM
Default Re: oil return on the sidewinder (kcjohnnyboy)
I know its wierd but I need one that is gonna make it in between the downpipe and dumptube, the sidewinder is a little tricky, but should be running monday
Old May 1, 2004 | 11:42 PM
ghettocrxsi's Avatar
You should hook up your water lines.
Just tap into the throttle body heater lines. Clip the hose and run each side the turbo. So it makes a loop. They help cool the turbo I believe.
ANd I would make a new oil return that one seems kinda janky. I would not want it to pop off and destroy your turbo and motor.
Old May 2, 2004 | 06:36 AM
Frozen E's Avatar
H-T White Ops
That's nasty. Get real hoses for crying out loud. A trip to the plumbing section at Ace Hardware is a shitty way of doing that.
Old May 2, 2004 | 08:07 AM
Default Re: (IslandSi)
I have a stainless steel braided line, but I only have about 3/4 inch space between the dumptube and downpipe, and I need to go in between them so I get a direct, path going down.
Can I get some more info on running the heater lines? Anyone have a pic on an ITR mani?
Should I just tap into this line, One end going in the other end going out???
Modified by 93dx--hatch at 9:18 AM 5/2/2004
FOrSfEd
Feb 1, 2004 04:33 PM
highmilehatch
Sep 28, 2003 07:52 PM
NuclearB18B
Jul 31, 2003 02:02 AM
T25 civic
Oct 15, 2002 12:52 PM
RATEDR
Jul 2, 2002 07:18 PM
