oil return line - shallow end?
Old Jun 13, 2005 | 05:43 PM
stockgreencivic's Avatar
Default oil return line - shallow end?
my drain hose lines up to the shallow end of the oil pan. i know most people tap their oil pan in the deep end, but is there an disadvantages of tapping it in the shallow end??
Old Jun 13, 2005 | 11:04 PM
EnzoSpeed's Avatar
Default Re: oil return line - shallow end? (stockgreencivic)
None that I can think of. Most people tap the deep part because it's the lowest part you can tap so gravity will help out the most.
You should be good as long as the turbo oil outlet is still higher than your pan fitting.
Old Jun 14, 2005 | 07:25 AM
Muckman's Avatar
Moderator in Chief
As long as its above the oil level in the pan your good to go
Old Jun 14, 2005 | 07:27 AM
GaRn's Avatar
I tapped mine right there on my H23 b/c is was the straightest line from the turbo.. works perfectly!
MalcolmV8
Dec 5, 2011 05:29 PM
lunareg
Sep 11, 2010 07:04 PM
turbochic
May 6, 2003 02:15 PM
b00stedsi
Jul 28, 2002 04:17 PM
Mr. Vapor
Oct 1, 2001 09:58 AM
