oil return line
Old Nov 13, 2003 | 06:41 AM
Turbo-Si's Avatar
Default oil return line
anyone have a pic of their oil return line going from the pan to the turbo??
Old Nov 13, 2003 | 07:04 AM
HXMan's Avatar
Default Re: oil return line (Ludesi)
Try a search...there are TONS of topics on this.
Old Nov 13, 2003 | 07:45 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: oil return line (HXMan)
there ya go. I pulled the line back a little since then away from the DP.
Old Nov 13, 2003 | 07:58 AM
Turbo-Si's Avatar
Default Re: oil return line (HybridcivicLS-T)
did you have to cut the steel braid from around the hose so it will fit in the AN fitting?
Old Nov 13, 2003 | 08:13 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
No it fit. I just ha d to cut the line to get it to loop and angle correctly.
Old Nov 13, 2003 | 08:22 AM
Foozball26's Avatar
the fittings are designed to where it fits perfectly with the steel braid.
otherwise the braided line would be worthless as all the pressure (in a pressurized line) would build up there and ....pop
Old Nov 13, 2003 | 09:41 AM
Flamenco-T's Avatar
go to my site, http://www.fast-turbo.com and click on Help Page on the bottom left corner of the page and there is a detailed assembly and installation instruction with pictures.
stan
Sketch_hs
Jun 23, 2005 02:11 PM
B18 CYA
Apr 21, 2004 04:34 PM
beepy
Mar 1, 2004 09:26 PM
Damon B.
Jan 30, 2002 12:32 AM
DamonBoost
Oct 24, 2001 12:11 AM
