Oil return
Old Nov 11, 2003 | 07:20 PM
Turbo-Si's Avatar
Default Oil return
Is it worth buying the oil return line kit which includes:
....the oil return FLANGE and gasket for the T3/T4 turbo
....½” NPT to –10AN aluminum pipe-to-flare adaptor
....straight auto fit hose end connector
....Stainless steel braided hose 16” long
....45 degree auto fit hose end connector
....special –10AN flare fitting with a 5/8” fitting
....a special 5/8” steel bulkhead nut that gets welded to the oil pan.
Or is this something i peice together at a local auto or hardware store and save money
Old Nov 11, 2003 | 07:48 PM
Flamenco-T's Avatar
Default Re: Oil return (Ludesi)
is it worth it, I would say yes. Those AN parts are prolly are rarity to find in yoru local home or auto part store, you'll prolly have to use a barb fitting and hose clamp. Drian flange is a must have, so there are if, and or buts about it.
Stan
Old Nov 12, 2003 | 04:09 AM
RedTegLS's Avatar
Where do you buy this kit your speaking of?
Old Nov 12, 2003 | 06:24 AM
Flamenco-T's Avatar
Default Re: Oil return (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">Where do you buy this kit your speaking of?</TD></TR></TABLE>
me
This is my kit,
Stan
00BoostedGSR
May 18, 2006 01:21 PM
d15b7racer
Oct 13, 2004 05:12 PM
harryg
Dec 2, 2003 12:02 PM
metal-x
Sep 15, 2003 09:58 PM
Boosthead
Dec 10, 2001 11:58 AM
