oil feed/return lines
Old Dec 10, 2001 | 11:47 AM
Boosthead's Avatar
Default oil feed/return lines
Can anyone tell me specifically what is included in the DRAG kit for oil feed and return lines? I did some searching and cannot find an itemized list. I was quoted about $100 from a DRAG distributor and this seems high. It seems I could buy these parts for less from Summit or Jegs
Old Dec 10, 2001 | 11:56 AM
chri5's Avatar
Default Re: oil feed/return lines (Boosthead)
basically a 90 degree bent piece of small metal pipe, a 6 inch section of radiator hose, and thats about it. It did come with a fitting for it to connect to the turbo.
Go with some better fittings and steel braided hose. Especially if they want $100
Old Dec 10, 2001 | 11:58 AM
Flamenco-T's Avatar
oil feed...
-1/8" NPT tee fitting
-4AN stainless lines (2ft)
-another part that goes to the center shaft housing, call Majestic turbo, ask what size it is and get a 90deg hose end from that size to -4an male
this is what drag gave you..., On the oil return, I wouldn't use any of their kit, get this from anplumbing.com
oil return
-1/2" flange from majestic female
-1/2"NPT male to -10AN 45 deg hose end
--10AN stainless lines 1ft
-1/2"NPT female to -10AN hose end
-1.2"NPT male flange (to the oil pan)
stan
teamidscoupe
May 16, 2007 05:02 PM
civicdx1
Apr 26, 2005 12:01 AM
boredracer408
Nov 16, 2003 04:26 AM
reignofchaos
Jul 27, 2003 10:34 AM
Ri5e
Feb 17, 2002 02:20 PM
