oil restrictor on a sc61???
Old Apr 29, 2009 | 08:47 AM
turboef90's Avatar
Default oil restrictor on a sc61???
i have one on a stock b16a running 10 psi. should i have one on it?? i have a 3/4 return line
Old Apr 29, 2009 | 09:01 AM
kyden's Avatar
Default Re: oil restrictor on a sc61???
you don't need one as long as you have a -3an line. i have 50k miles on my sc34 with no issues.
Old Apr 29, 2009 | 09:56 AM
turboef90's Avatar
and one else??? thanx kyden for the feedback makes me feel litt better lol i havent been running one on either but i just would to blow the seals out alreayd only had it for maybe 2 years driving only on the weekends with it
Old Apr 29, 2009 | 10:44 AM
TheShodan's Avatar
Moderator
for a honda -3AN is standard - no restrictor as long as you have no oil system modifications
Old Apr 29, 2009 | 12:16 PM
s2kdre's Avatar
i ran my sc61 with a -3an and a -10 return for 50k miles with no restrictor.
Old Apr 29, 2009 | 06:45 PM
Accord SiRT's Avatar
I've had my SC61 since 2004 running a -3 an oil feed and a -10 an return line and no restirctor and haven't had any issues.
Old Apr 30, 2009 | 12:01 AM
civic efb16's Avatar
if your runnin a -3 is it still okae to run a oil restrictor
Old Apr 30, 2009 | 07:06 AM
TheShodan's Avatar
Moderator
Not the best idea, but it is best to check your oil pressure to be sure
Old Apr 30, 2009 | 12:08 PM
Project_EK's Avatar
what if your running a -4AN feed? what size restrictor would u rec.?
Old Apr 30, 2009 | 03:20 PM
Tjabo's Avatar
I'm running mine (EDIT: clarifying that it's an SC6152sp) with a -4 feed from the block (no restictor) and a -10 return line. It's a Neon though, so oil pressure may be lower than a Honda from the sounds of it.
Anyway, I spoke with a guy from Precision about this, and he is the one who told me to run a -4 (instead of the -3 I had) from the block where it is as close as possible to full oil pressure.
It has been running great for about a year this way so far.
Old Apr 30, 2009 | 04:23 PM
turboef90's Avatar
thanx for the feed back!!!! ya thats what i have 3an line to it. its just i see 80 psi etc. just didnt want to blow the seals out and pay 185 for them to replace it.
Old May 1, 2009 | 05:09 AM
twkdCD595's Avatar
-4 AN feed off the an GE oil filter adapter. -10 AN return.
No restrictor, no problems... my motor sees plenty of oil pressure too.
Old May 4, 2009 | 12:58 AM
okae i have almost the same question so might as well bump this back up instead of me makin a new topic okae guys i have a sc34 i guess its suppose to run a -4 but im goin to convert it to a -3 do i need to run a oil restrictor or it should be fine thanks
4tika4
Feb 3, 2012 02:27 PM
velisma
Jul 20, 2010 01:18 PM
sampol999
Sep 3, 2006 01:09 PM
Ad4mGSR
Jul 23, 2004 01:15 PM
hackish
May 17, 2004 09:45 AM
