... oil residue on engine block
Old Aug 14, 2002 | 07:02 AM
1.8T_EG's Avatar
Default ... oil residue on engine block
... okay, i just a custom turbo kit installed in my civic... i was doing a weekly check up of the bolts, hoses, fluids, etc when i noticed an oily residue buildup on the block directly behind the turbo... what is this a sign of?... turbo leaking oil?... if so, is this a faulty turbo?... or can this be fixed?... lemme know... thanks in advance...
Old Aug 14, 2002 | 07:38 AM
CovertFI's Avatar
Default Re: ... oil residue on engine block (1.8T_EG)
behind the turbo? where like were the head gasket is? i cant exactly imagine where that is
Old Aug 14, 2002 | 07:49 AM
b18bturbo's Avatar
Default Re: ... oil residue on engine block (CovertFI)
probably just little blow by through the seals nothing major to worry about.
Old Aug 14, 2002 | 11:04 AM
1.8T_EG's Avatar
... just in case (can never to cautious)... what steps should i take and what things should i check to make sure that it is not something that could be damaging to my engine?... lemme know... thanks...
Old Aug 14, 2002 | 11:16 AM
Kamin's Avatar
if your really worried you can have a leakdown test performed.
Bunta eg6
May 1, 2005 04:38 PM
drift4food
Apr 8, 2005 05:07 PM
MikeMAN
Mar 4, 2003 04:35 AM
