Oil pump probs
Old Sep 9, 2003 | 09:24 AM
JDMCRX's Avatar
Default Oil pump probs NEED HELP LOW OIL PRESSURE
Ok here it is my friends 91 crx with a b16a and turbo with a 95 delsol b16a pump in it his oil feed is -4 and return is -10. now when the motor idles under 1000rpm oil light is on and the oil presure gauge reeds like 2psi what is going on.
1 the oil feed is too big??
2 oil pump is fucked
3something wrong in the motor
me lost
Modified by JDMCRX at 8:36 PM 9/9/2003
Modified by JDMCRX at 8:37 PM 9/9/2003
Old Sep 9, 2003 | 11:37 AM
JDMCRX's Avatar
Default Re: Oil pump probs (JDMCRX)
Anyone??
Old Sep 21, 2003 | 07:27 PM
LudEcrous's Avatar
i have the same problem in my built h23.....i'm trying the oil pickup first and then go from there.
Anyone have any other ideas?
Old Sep 21, 2003 | 07:41 PM
SJP0tato's Avatar
Default Re: Oil pump probs NEED HELP LOW OIL PRESSURE (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">1 the oil feed is too big??
Nope, I'm running a -4 feed -10 return on mine and it works fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">2 oil pump is fucked
Sounds like a possibility
3something wrong in the motor </TD></TR></TABLE>
Also sounds possible. Maybe a bad bearing, oil pump problem, or something with the oil pickup as mentioned before could cause this. Where's the oil pressure guage getting it's reading from? Sometimes a bad placement can cause faulty readings, but if your oil light is on only at idle it really sounds like something's majorly wrong with the motor. I'd tear it down & find out what's wrong before driving it anymore...0-2 psi at idle is a quick ticket to ruined bearings-ville. :-/
Good luck man,
Ryan P.
Old Sep 21, 2003 | 08:59 PM
hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">when the motor idles under 1000rpm oil light is on and the oil presure gauge reads like 2psi</TD></TR></TABLE>
Ok, what gauge? is it the 0-100 psi autometer? They are known for being off at idle... if your oil light is on, how is (the sender) connected? Tee fitting?
Start be getting a better (test) gauge...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote"> his oil feed is -4 and return is -10. </TD></TR></TABLE>
My oil feed is -3 AN... I though most are. A -10AN return line is OK...
Have you changed the filter and checked the oil level?
Old Sep 22, 2003 | 08:05 AM
JDMCRX's Avatar
Default Re: Oil pump probs NEED HELP LOW OIL PRESSURE (hybridsol)
Ok changed the motors put the Built bottom end in and the new head and new HONDA oil pump primed it. Honda oil Filter and changed the oil feed to -3 now the oil light comes on the same thing and its a new Honda sensor.
Now im thinkin the head is fucked cause this head is the one off the other motor so we are going to try tonight to change the Head to a stock B16A one and see if not then im lost
Old Sep 22, 2003 | 08:17 AM
CRX T-Si's Avatar
I agree with - SJP0tato -
Take that baby apart before any damage could be done to it.
Safe then sorry as they say......
Dec 28, 2008 05:00 PM
caspers_hatch
Nov 12, 2005 11:37 PM
turboman
Jul 19, 2005 08:28 PM
eag36
Mar 30, 2005 05:40 PM
