Oil Pump help/opinions
Old Jan 7, 2009 | 02:57 PM
XxINLINExX's Avatar
Default Oil Pump help/opinions
Ok so im finishing up my turbo set up on my LS integra and was looking into changing the oil pump. Will a new OEM replacement work well or should i buy a high flow pump? Did any of you turbo guys change your pumps?
Here's some info on my set up:
Parts on the Cylinder Head:
Crower Camshafts
Crower Valve Springs
Crower Retainers
KMS Valves ( std size)
Port & Polish
Cylinder Block:
LS Pistons
Block Guard
LS Rods
New Bearings
Not looking to make much power but just trying to beef up the motor a bit.
Old Jan 7, 2009 | 03:43 PM
Ls_dx's Avatar
Default Re: Oil Pump help/opinions
Ideally a nice p30 or p73 oil pump would be nice. or a new p75 LS. but ONLY get a honda oil pump ONLY!!!
Old Jan 7, 2009 | 05:43 PM
boostedcivicsir's Avatar
Mr. Badwrench
i have only ever used an oe pump. making over 700 on a stock itr pump.
Old Jan 7, 2009 | 08:58 PM
nello a.'s Avatar
two @600hp cars on oem.
had a grenade problem that was traced back to a bad crank pulley and no dowel pins between the tranny and block. no problems since.
Old Jan 8, 2009 | 05:34 AM
XxINLINExX's Avatar
Will do thank you!!!
Thank You guys also.... how are you guys making those crazy numbers? Whats your set up?
Old Jan 8, 2009 | 08:09 PM
nello a.'s Avatar
built bottom end. nice turbo and manifold. msd, odds and ends AND a really good tune
Old Jan 9, 2009 | 04:30 AM
non-VTEC's Avatar
i used a brand new OEM oil pump on my current build. right from startup i had a low oil pressure issue. about 50-55psi MAX.
so i looked for a different solution and i came up with this: http://cgi.ebay.com/ebaymotors/B16-B...Q5fAccessories
he basically take a new OEM pump and ports it out. puts in a new billet oil pump gear and shims the relief spring for more pressure.
endyn offers the same service but without changing the gear rotor.
i now get a solid 80psi of oil pressure. and it can go as high as 90-95psi before the relief valve opens and settles to 80-85psi.
most people have good luck with a untouched OEM pump.
Old Jan 11, 2009 | 09:43 PM
JDMTurboEG6's Avatar
i have the endyn pump on my motor very pleased with its performance
Old Jan 11, 2009 | 10:44 PM
ShawnR's Avatar
i was always a little scared to run the oem oil pump gears so i always use the toda gears in a oem housing
keychild486
Apr 2, 2008 04:58 PM
lsturbo*
Oct 4, 2007 07:48 PM
astralshadow
Jun 12, 2006 06:38 PM
InfamousRS
May 1, 2002 08:12 PM
Gonzo
Feb 14, 2002 03:37 PM
