oil problems after turbo install???
Old Jul 18, 2008 | 05:47 PM
vinEyFB16A's Avatar
Default oil problems after turbo install???
Alright so i just helped my buddy put a turbo setup on his 2000 si and now the oil light flickers at idle and goes away off idle. and also vtec does not engage (assuming cause of oil pressure).. Motor had no problems before install... anyone have this problem before??
Old Jul 18, 2008 | 06:20 PM
ITR.#1446's Avatar
Default Re: oil problems after turbo install??? (vinEyFB16A)
did you tap into the oil pressure sensor for a oil feed line?
Old Jul 18, 2008 | 08:12 PM
welfarepc's Avatar
yeah... where are you getting your turbo feed from?
maybe you spun a bearing on a test run?? i hope not.
Old Jul 18, 2008 | 08:35 PM
vinEyFB16A's Avatar
Default Re: (welfarepc)
the oil feed is from the pressure sender. back of the block nest to the oil filter
Old Jul 18, 2008 | 08:41 PM
ITR.#1446's Avatar
Default Re: (vinEyFB16A)
i would check to make sure the connection is good
Old Jul 18, 2008 | 09:20 PM
one-cam's Avatar
Default Re: (ITR.#1446)
Old Jul 18, 2008 | 09:53 PM
vinEyFB16A's Avatar
connection? there is no oil leak
Old Jul 19, 2008 | 10:58 AM
vinEyFB16A's Avatar
bump fpr anyone
Old Jul 19, 2008 | 12:25 PM
welfarepc's Avatar
well the oil light comes on when pressure falls below 10psi
so your friends oil pressure is dangerously low
if there isnt a leak, and your stock sender works (he should have an oil pressure gauge he can check for actual readings) then he prolly [freak]ed something up internally.
how many litres of oil are in the car?
Old Jul 19, 2008 | 01:49 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">well the oil light comes on when pressure falls below 10psi
actually the light comes on when there is less than 3-5psi......so ya if his light is flickering then something is seriously wrong.
try dumping the oil and filter. put a new filter and some thicker oil and see if it helps.
Old Jul 19, 2008 | 02:42 PM
vinEyFB16A's Avatar
Default Re: (non-VTEC)
everything was operating normally before we put the turbo kit on.. after that right at start up it started so i dont think anything internally is messed up.. it could be the sender but would that cause vtec not to engage? also there is about 4 and 1/2 quarts of oil in it.
Old Jul 20, 2008 | 06:07 PM
vinEyFB16A's Avatar
anyone else??
Old Jul 20, 2008 | 07:07 PM
riddlinkid1986's Avatar
i put the stock Oil Pressure sending unit on a T fitting taped at the top of my turbo, in my oil feed line. Then i run a T on the back of my block with my oil pressure gauge sending unit, an my oil feed for my turbo.
I have no pressure on first start of the day, its a good way to test if your oil drain line flows good! my oil light is on for a sec on start up, then goes away once oil reaches my turbo.
oil pressure for car at idel should be about 18psi. Cold it will be like 40, some times 80.
Change your filter, check all your fittings, check your drain line, cause if it dose not have a smooth slope with no bends it will not drain fast enough an you can blow your oil pump, or when you start up in the mornings you might see alot of oil smoke cause it will push its way through your turbo seals. BEEN THERE BEFOR!
Get a gauge from a auto parts store bro, go from there.
Old Jul 21, 2008 | 10:08 AM
vinEyFB16A's Avatar
Default Re: (riddlinkid1986)
aight thanks man. were workin on getting a gauge hooked up but the first one was junk and read 10 psi no matter what when the key is on. so he's gonna put a mechanical one on then were gonna check out the pressures.
Old Jul 21, 2008 | 03:53 PM
champLSinteg's Avatar
How do you know vtec is not working? Did you put the turbo kit on and then take it for a spin?
Did you get a check light?
Old Jul 23, 2008 | 04:28 PM
vinEyFB16A's Avatar
Default Re: (champLSinteg)
no check light.. on the dyno it didn't engage. because at first we thought it was an electrical problem with the sender cause when you jiggled the conection the light would turn off... there is a dent in the oil pan and i think it might be restricting the pickup... otherwise its gonna get a new pump cause its not making anypressure.
Old Jul 24, 2008 | 05:57 PM
vinEyFB16A's Avatar
new oil pump and pan are in.. gret pressure now.. the dude we bought the turbo kit from cold welded the oil return fitting in the pan and it melted and cold weld was all over in the oil.. clogged the oil pickup.. prolly the filter, and messed up the pump.. but hopefully none made its way into any galleries or to the rest of the engine. but all in all its got oil pressure now and thanks for everyone's help.
compact-tuner
Sep 3, 2006 10:51 PM
ALL IMPORT
Jul 23, 2006 02:43 PM
99Sivic
May 7, 2006 01:39 PM
ham
Sep 29, 2005 12:49 PM
jdkornlp
Sep 22, 2005 03:48 PM
