oil pressure light???????
Old Aug 14, 2010 | 06:13 PM
turboman2.2's Avatar
Default oil pressure light???????
ok i was test running my car after some repairs, at wot my red oil light turned on the highway so i shut my engine off right away and pulled over, topped off the oil as needed and turned it on exited and it stayed on, at the stoplight i turned it off and on and it turned off. I went on the on ramp onto the highway cruising at 55mph at 3000rpm and as soon as i released the throtle and let the car slow down a little it turned on again and sayed on for a quarter mile until i pulled over and had it towed to my garage. So i noticed it was leaking some oil and it might be coming from the oil pressure sensor. Would this cause the light to come on if it is indeed leaking from there? Hopefully its this and not the rod bearing. The amount of oil leaking is around the size of a basket ball flat> hopefully its not the rod or main bearings..
Old Aug 15, 2010 | 11:36 AM
Default Re: oil pressure light???????
bump< bump<
Old Aug 15, 2010 | 11:45 AM
street_ride14's Avatar
you do have an oil pressure gauge right ?
check your pressure sensor wire.
Old Aug 15, 2010 | 09:27 PM
no its the stock sensor
Old Aug 16, 2010 | 01:45 PM
Hybrid96EK's Avatar
The stock sensor comes on at 4psi, so I was told. By the time this thing comes on your hosed. If you had a bad bearing, you should certainly be able to hear it. You drove a good amount with the light on which concerns me. I have seen the sensors get full of crap and falsely come on. If I were in your shoes I would pull the sensor and make sure its not blocked with crap. Clean up the back of the block and then use some teflon tape or Hondabond on the threads of the sensor and put it back into the block. See if the light is still coming on. I do know that if the wire comes off or has a break in it, the light will go OFF by default, not on. So that rules out a wiring/connection problem. You really need to figure this out though before you drive this car anymore. If not then you could be looking into some very costly repairs that will only compound over time.
Old Aug 16, 2010 | 07:03 PM
i still havnt taken the time to jack it up and take a better look but i will, i felt around the sensor and it feels like its really leaking from there
Old Aug 22, 2010 | 07:09 PM
turned out it was a cracked sleeve was one of the bigger problems...
Old Aug 23, 2010 | 02:28 PM
welfarepc's Avatar
hm. you seem to have no luck.... hope the next one turns out better.
Old Aug 23, 2010 | 03:14 PM
Turbo-LS's Avatar
that sucks, i was gonna ask if you were running a kicked out sump oil pan aka moroso drag pan
curtie94
Jan 31, 2012 06:16 PM
joker4096
May 2, 2010 08:27 PM
eag36
Apr 6, 2005 07:55 AM
livelife46290
Jul 14, 2004 05:15 AM
96b18c
Feb 23, 2003 10:45 PM
