oil pressure help?
Old Dec 19, 2008 | 09:18 PM
columbushatch's Avatar
Default oil pressure help?
finally got my motor together and primed the oil but the gauges reads "0". I unhook the "T" where the sender is at and breifly start the engine and oil comes out (So oil is going through the -3an feed line) I hooked up everything and start the motor and pressure still reads "0". install seems to be correct and sender was shipped back and retested and its good. any trouble shooting tips? thanks in advance.
Old Dec 19, 2008 | 09:34 PM
V-SPEC 1's Avatar
gauge bad?
Old Dec 19, 2008 | 09:54 PM
Garcia-Racing's Avatar
not grounded?
Old Dec 19, 2008 | 10:12 PM
ABK's Avatar
ABK
put some regulated air into the sending unit. See if the gauge reads, if not measure the voltage coming out of the unit. Do you still have the stock unit hooked up? If so crank the engine without ecu fuse in it until the oil light goes off. You are supposed to do that anytime you build the engine or let it sit for over a month.
Old Dec 20, 2008 | 01:11 PM
yes, stock unit is still hooked up and can't figure this out
Old Dec 20, 2008 | 01:28 PM
ABK's Avatar
ABK
does the oil light shut off if you crank the egine like 3-5 times for 10 seconds?
Old Dec 22, 2008 | 09:45 AM
Default Re: oil pressure help?
the factory oil light doesn't turn on and I tested the gauge and sender by putting compress air in and it works (reads psi). I can not figure out why it wouldn't read any oil pressure when its evident that there is oil traveling through the feed line. any ideas would be greatly appreciated
Old Dec 22, 2008 | 09:57 AM
dpetro1's Avatar
if the sender and gauge are confirmed good then i would look into the wiring
sirtef9
Engine Machining & Assembly
Jun 8, 2017 04:56 PM
jesussijalbo
Apr 25, 2014 05:21 AM
krazyhmongboi
Jun 8, 2007 10:47 AM
Prudz_lude
Feb 25, 2007 12:33 AM
DelSol-B-18
12
Apr 17, 2005 09:42 AM
