oil pressure
what are causes of low oil pressure and what can happen if your oil pressure is low?
I believe mine is on the low side... should i worry? this is a stock 96 civic dx.
what is the minimum oil psi it should be at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">You say you have low oil pressure... what are you comparing it to? Give numbers and some details about your setup.</TD></TR></TABLE>
It's just a stock motor. My friend gave me an oil pressure gauge he had that he was gonna throw out (an el cheapo one) so I just put it on so I could monitor the health of my motor. It's reading around 5-10psi at idle after the car is warmed up
