Oil pan tapping help
Old Feb 24, 2003 | 09:17 PM
B20-T's Avatar
Default Oil pan tapping help
i have my oil pan tap on the left side of the oil pan before it goes into the big slot with a pipe coming out of it..is it ok if i tap it there?
Old Feb 24, 2003 | 10:44 PM
Trac226's Avatar
Default Re: Oil pan tapping help (B20-T)
Huh? A picture might help. As long as you got a negative slope on your oil return line coming into your pan, it should be fine. Also, make sure that your tap is above the normal oil level.
delslow45
Apr 3, 2011 07:14 PM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
fandango
Jan 20, 2005 06:20 PM
turbochic
May 6, 2003 02:15 PM
