Oil pan tap
Old Jul 18, 2005 | 08:18 AM
mahatma's Avatar
Default Oil pan tap
I'm rebuilding a '92 LS motor for turbo. Have forged internals, etc.
Won't be boosting until I break it in. Motor is going to the machine shop this week and I'd like to have them tap the oil pan now so I don't have to mess with it later.
What do I ask for? Size, etc.....also where exactly on the oil pan would be the ideal place?
Old Jul 18, 2005 | 08:26 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
you are talking about the return line right? i dont know much about the size but you want the fitting to be around 1/4 up from the bottom of the pan. and from what i hear the it is best if the line makes a 90 degree angle from bottom of turbo housing to the oil pan. anyone correct me if im wrong
Old Jul 18, 2005 | 09:34 AM
HiProfile's Avatar
Default Re: (h22boy)
Fitting size should be 1/2" NPT (National Pipe Thread). A 3/8" fitting would be as big inside as the -10 AN line you should use, but bigger is always better. 1/2" is the defacto standard, and most common to find the right brass fitting at a hardware store.
btw - search for breakin techniques, all you really need are the rings to seat properly, and that can be done in a day if done right (a week at most). Not trying to start a discussion on it here, just read it (its a big thread) and decide for yourself.
Old Jul 18, 2005 | 10:25 AM
mahatma's Avatar
Default Re: (HiProfile)
OK so regardless if I go with 1/2" or 3/8", I can still adapt lines to fit that as well as my turbo (wanting a T3)??
sorry i'm a turbo n00b.....
Should this be tapped so the hole faces the radiator or the firewall.....or other??
Old Jul 18, 2005 | 11:54 AM
notoriousB's Avatar
Default Re: (mahatma)
you need to tap it high on the pan and close to where ever your turbo's return will be. every set up is different depending on turbo/mani, so the best bet is to mock up the mani/turbo and figure it out from there.
don't mess with brass fittings, get a weldable -10 AN male connector and have it welded to the pan.
Old Jul 18, 2005 | 05:34 PM
jdm-ray's Avatar
for an ls your return line is the short stubby line. the fitting should go in the front of the pan 1/4 way up from the bottom. the feed line is the long skinny one. it goes on the back of the pan facing the firewall.
Luis Valdez
Honda Civic (2006 - 2015)
Feb 8, 2009 06:03 PM
fig
Sep 27, 2006 01:51 PM
toolowsol
Feb 9, 2006 01:52 PM
dunkd
Mar 8, 2004 09:07 PM
fastludeh22
Oct 29, 2002 11:41 PM
