Oil Pan
Old Mar 17, 2002 | 11:14 PM
SlowB16's Avatar
Default Oil Pan
Did all of you take the oil pan off when you put your turbo on? Someone told me that you dont have to, and that way I wouldnt have to get a new gasket. I figure he is wrong. Is he?
Old Mar 17, 2002 | 11:22 PM
Etylorcen's Avatar
Default Re: Oil Pan (SlowB16)
If you dont take it off when you drill the metal shaving will fall into your oil. Its not that hard to take it off. There are like 20-25 little bolts and nuts. Just take it off...as for having to replace it I dont think its absolutely nessessary but you might as well.
Old Mar 17, 2002 | 11:25 PM
SlowB16's Avatar
Default Re: Oil Pan (Etylorcen)
that is what I figured.
Old Mar 18, 2002 | 06:59 AM
ATurboCivic2NV's Avatar
just remember the oil pan gasket is a dealer only item!!! i learned that the hard way.
Old Mar 18, 2002 | 10:58 AM
pornstarSR's Avatar
yes take off he oil pan, it may take some time but better now, because when you blow the motor and turbo from the metal inside your motor you will have to rip it all down....and thats way more time...
do it right the first time
93LSivic's Avatar
Default Re: Oil Pan (ATurboCivic2NV)
No its not. Felpro makes them also.
Oh, yeah it is recommended that you pull the pan off.
Old Mar 18, 2002 | 11:08 AM
Default Re: Oil Pan (93LSivic)
when i did mine i check every auto parts store in my city about 5 total. no one carried it
Old Mar 18, 2002 | 11:11 AM
93LSivic's Avatar
Well, you might be right. Correction then: LS motors, the oil pan gasket is available. B16 should be the same pan though? Hmm
Felpro P/N OS 30630 R
States its for 90-96 1.8 motors, says nothing about 1.6
Old Mar 18, 2002 | 11:14 AM
mine was a d16 so maybe that is why no one had it
Old Mar 18, 2002 | 11:20 AM
TurboSedan's Avatar
New User
Yeah, I could imagine the damage to the turbo bearings and other interal engine components from chunks of steel in the oil!
Old Mar 18, 2002 | 11:40 AM
Default Re: Oil Pan (97CivicFerio)
well you oil screen <U>should</U> block out most of it then your filter would get the smaller ones. i would not chance it tho. big risk!!
Old Mar 18, 2002 | 01:09 PM
SlowB16's Avatar
Soi how much is a new gasket? I have a first gen B16 so I think it is the gasket from the del sol that fits it correct?
Old Mar 18, 2002 | 01:13 PM
i think so. just tell the dealer it is a b16a not a2 and he can figure it out
Old Mar 18, 2002 | 01:21 PM
Damon B.'s Avatar
25-30 bones.
projectej8
11
Apr 3, 2005 02:45 PM
LAKER HATER
May 21, 2004 07:51 AM
MR. ARIZONA
Sep 3, 2003 05:04 PM
swlabhot
Aug 21, 2003 04:38 AM
crxtremes
11
Oct 17, 2002 01:19 PM
