Oil line routing
Old Mar 23, 2003 | 03:10 PM
turbospool's Avatar
Default Oil line routing
Where do you guys have your oil feed line routed? Post setups. From back of block to tranny side or from back of block to the timing belt side?
Also in front of the turbo or behind the turbo between the block and the turbo for the feed line? thanks
Old Mar 23, 2003 | 05:42 PM
Danger's Avatar
Default Re: Oil line routing (turbospool)
when i had my rev hard kit i ran the oil line from the back of the block , to the tranny side and then to the back of the turbo . either front or back of the turbo , wouldnt matter .
i have did it they way on a couple of set-ups . sorry no pics .
Old Mar 23, 2003 | 05:56 PM
5thgencivic's Avatar
Old Mar 23, 2003 | 06:01 PM
turbospool's Avatar
Default Re: Oil line routing (5thgencivic)
cool, thanks, any more opiniions?
Old Mar 23, 2003 | 06:28 PM
Smashback's Avatar
Doesn't matter whatsoever. Pressure isn't gonna change from side to side. Just make sure it doesn't lay on anything hot. Also watch out because steel covered lines are abrasive so they can damage other things in your engine bay.
Old Mar 23, 2003 | 07:02 PM
turbospool's Avatar
Default Re: Oil line routing (Hatchblack)
yeah i kno, i just want to see what people have their lines configurated.
Old Mar 23, 2003 | 07:19 PM
Smashback's Avatar
I think the most common is tranny side, I've had mine like that on the SOHC and DOHC. Keeps it away from the belts and exposed cam gears
Old Mar 23, 2003 | 11:28 PM
GOLDBERG's Avatar
can you put oil line in/through that channel on the right side of the valve cover?or will that be too hot?
Old Mar 24, 2003 | 08:40 AM
Flamenco-T's Avatar
Default Re: Oil line routing (GOLDBERG)
you can route them anyway you want, there's a reason we went with stainless steel braided hose, it can withstand a hot temp under the hood. As long as it does not touches any hot object such as downpipe, exhaust and etc, you should be fine..
use your common sense, make sure you have air space around the lines, use a zip ties so it doesn't get caught on belts and etc..
stan
Old Mar 24, 2003 | 09:03 AM
psi420's Avatar
I have mine routed on the tranny side.
Old Mar 24, 2003 | 09:10 AM
CRX SiR T's Avatar
Default Re: Oil line routing (Flamenco-T)
i ran it on the timing belt side. my line wasnt long enough to go around the tranny side, and i didnt want it to hit the exposed timing belt, so it goes across the valve cover in that crease
Old Mar 24, 2003 | 01:26 PM
GOLDBERG's Avatar
Default Re: Oil line routing (CRX SiR T)
did that post any problems with you??? such as line melting or something?
Old Mar 24, 2003 | 01:44 PM
CRX SiR T's Avatar
hasnt so far. i've seen a few other cars around here with the line ran the same way, so i really dont think it would pose a problem. i know that the line will stay in place though, and not move around and possibly melt something. it only gets in the way if you want to remove the valve cover.
well....besides that it could scratch my valve cover, it will be fine
[Modified by CRX SiR T, 10:45 PM 3/24/2003]
Old Mar 24, 2003 | 07:06 PM
turbospool's Avatar
I bougth a fitting that goes on my turbo, its a straight fitting instead of the starndard bent L shaped one. So now the oil feed line feed directly on top instead of being bent cuz of hte other fitting. Is this bad in anyway? with the other fitting the line hit my radiator and fan shrowd. thanks
vladd
Sep 21, 2006 07:54 PM
DIYMIKE
Jan 24, 2006 05:14 PM
integra-modder
May 5, 2005 11:13 PM
dohcvtec717
Apr 1, 2002 06:58 PM
JohnShaft
Aug 14, 2001 12:27 PM
