this oil line return ok?
Old Apr 4, 2007 | 01:46 PM
  #26
Flexin5's Avatar
i see, thanks for the help guys, or else i would have had a big mess on the garage floor.
so i'll go grab a nut that fits that thread, and weld or JB weld it onto the outside of the pan and then screw in the fittnig?
Old Apr 4, 2007 | 02:40 PM
  #27
stealthmode62's Avatar
Default Re: (Flexin5)
You can jb the threads and screw the fitting all the way in to the base. You don't need to torque it. Let the jb on the threads cure and then put another layer on the outside base of the fitting. As long as your metal is clean, that barb isn't ever coming out.
Anyone who tells you this won't work hasn't done it before. Wether they've only used higher end fittings or never modified an oil pan at all, they haven't done it.
Old Apr 6, 2007 | 09:28 AM
  #28
JST1CAM's Avatar
Default Re: (stealthmode62)
im doing this tonight. Pan is coming off and im gonna let it sit all night. :D
Old Apr 6, 2007 | 11:56 AM
  #29
slvrstns2000's Avatar
Default Re: (JST1CAM)
i personally like this method the best.
Old Apr 6, 2007 | 01:06 PM
  #30
JST1CAM's Avatar
Default Re: (flatblackEK)
^^thats a nice setup.
That fitting welded to the pan?
Old Apr 6, 2007 | 03:00 PM
  #31
non-VTEC's Avatar
Default Re: this oil line return ok? (Flexin5)
looks good!
i've had my oil pan tapped the exact same way with a threaded brass barbed fitting held in with JB weld. no leaks and its been like that for over 2 years.
everyone claiming that the fitting will "rip" through the metal of the oil pan has no clue.
never underestimate the powa of JB weld yO!!!!!
Old Apr 6, 2007 | 08:04 PM
  #32
shortyz21's Avatar
if you do JB it MAKE SURE AS **** THERES NO OIL ON ANYTHING...
wash it with acetone.. or something
jb works, welded is better
Old Apr 11, 2007 | 10:23 AM
  #33
earls fittings, welded to oilpan
Hatch99
Sep 13, 2007 12:08 AM
Rod.
Jul 4, 2005 10:17 PM
birz
Jun 4, 2004 06:03 AM
FOrSfEd
Feb 1, 2004 04:33 PM
PrecisionH23a
Sep 16, 2003 04:21 AM
