Oil leaking from the Turbo
Old Dec 20, 2003 | 04:59 PM
vteccivicracer03's Avatar
Default Oil leaking from the Turbo
Ok I have a 94 Civic with the greddy turbo kit boosting 11 psi and i started to notice that the turbo was leaking oil from the inlet side of the turbo. I took the charge pipe off the turbo and there is oil in there too. I know that it is not my piston rings or anything because i did a compression test and it is fine 180. Is it leaking oil from in the turbo and do i even need to do a rebuild? Also what turbo is the greddy kit for a 92-95 civic vtec? 14b?16g? It says TD04H on the housing.Anyway i took the turbo off all the way and took it completely apart for a rebuild, but i havent got my rebuild kit yet. This is the website for the rebuild http://www.vfaq.com/mods/Turbo-rebuild.html I thought the turbo was a 16g but on the website it says that the back of the 16g compresser wheel is tapered and mine is flat like the 14b. PLEASE HELP!!!!
Old Dec 20, 2003 | 08:06 PM
Johnyquest's Avatar
Default Re: Oil leaking from the Turbo (vteccivicracer03)
Yours in not the 16, i think it is the 14b, maybe it's 15-somthing. That sounds about right... The 16g is the one all the eclipse guys upgrade to so I KNOW that's not it. You could have probably gotten away w/o a rebuild, but it really depends on how bad it is. If it's significant, then you need to do it. I *think* those directions will work for your turbo to. I hope you marked the wheel alignment... balance is important!
Good luck!
Old Dec 20, 2003 | 09:08 PM
It was leaking really bad...it leaked all my oil out in 1 day. Oh and i did mark it so i can get it aligned right too. I bought the turbo off a friend that bought it new and only had it for a year. I just wouldn't think that it would be time for a rebuild. Any one else have any input?
Old Dec 21, 2003 | 10:06 AM
help please!!!!!!!
Old Dec 21, 2003 | 02:33 PM
pollito's Avatar
Turbo seals are gone. Need a rebuild. BTW, it's a Mitsu td04-15g
EKris
Jul 22, 2008 02:09 PM
steve96accord
Jun 30, 2006 09:40 PM
racer4200
Sep 7, 2001 04:58 AM
