oil leak...
Old Oct 10, 2001 | 05:05 PM
KekeK-18's Avatar
Default oil leak...
I'm using earls fittings and there is a minor oil leak on the thread of my oil return line from the oil pan. I try to retighten the fittings and it still leak... will wrapping the tread with teflon tape before tightening it up help? Any other suggestions?
Old Oct 10, 2001 | 05:07 PM
dustin's Avatar
Default Re: oil leak... (b18cturbo)
Mine leaks a small amount too. Maybe a drop every couple weeks.
Dustin
Old Oct 10, 2001 | 05:45 PM
KekeK-18's Avatar
Default Re: oil leak... (dustin)
Yeah, thats what I'm talking about... What bothers me is it stain my garage floor....
So do you think teflon will work?
[Modified by b18cturbo, 6:46 PM 10/10/2001]
Old Oct 10, 2001 | 05:47 PM
LsTurbo91's Avatar
mine leaks too for some reason. only a drop for a week or so.
Old Oct 10, 2001 | 05:48 PM
dustin's Avatar
Well, my oil return is an AN fitting and you cannot effectively use teflon tape on AN fittings. The threads are not supposed to be exposed to any fluid... AN fittings seal by compression of the inner flange only.
I have REALLY tightened mine to the point I thought it was going to snap, and it would still slowly leak a drop or so.
I never see any drip on the ground, but if I wipe it off it will be back in a week or two.
Dustin
accord_raffi
Jan 27, 2009 07:29 PM
hondaeg8
May 22, 2006 03:12 PM
LSVtechnologytur...
Sep 17, 2005 01:46 PM
E Swift
Nov 2, 2002 09:17 AM
DC2R714
Jul 19, 2002 05:25 AM
