Oil feed line question
Old May 26, 2009 | 03:01 PM
nihad's Avatar
Default Oil feed line question
Ok i have 2 questions to ask
First is i have a 60Trim BB T3/T4 ptb my question is what oil feed line do you guys run i had a 4an and was convinced to switch to a 3an.. I have the proper t3 bb oil restrictor..
And i was gonna add a magnet in the oil pan its a bigger magnet 1in wide 1/4 tall do any of you guys use this method..
Old May 26, 2009 | 03:09 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Oil feed line question
.0035 restrictor and -3 line. you really need to know what oil pressure you have first.
Old May 26, 2009 | 03:32 PM
Bailhatch's Avatar
what does the magnet have to do with the feed line?
Most people use a magnetic drain plug so they can can see what ferrous metals it got without taking the oilpan off.
Old May 27, 2009 | 02:42 PM
nihad's Avatar
Um my oil pressure is 80-95 psi at cold start up but then at 500rpms its about 10psi then 1.2k its 25psi 3k its 55-60 psi.. I had a 4an line before and now i purchased a oil kit from stealtmode and i have the oil restrictor that is designed for the turbo its a aluminum restrictor with a 4an male fitting..
The magnet would be for if there was a problem or some metal shavings it would have a better chance of sticking to the magnet. and no they dont have nothing to do with the feedline..
Old May 27, 2009 | 04:17 PM
Bailhatch's Avatar
you know none of the bearings in your engine or turbo are not made of anything that will stick to a magnet right?
Old May 27, 2009 | 05:37 PM
nihad's Avatar
Ok i am not 100% sure if the bearings are made out of steel but its some kinda of a alloy and when there is friction on the alloy guess what happens it magnetises so it will stick to the magnet..
Dre90
Apr 20, 2010 04:11 PM
StolenTeg
Aug 15, 2005 06:06 PM
BEEYOND
Sep 3, 2004 01:10 AM
MikeMAN
Jul 2, 2002 09:25 PM
