Oil Feed line question
Subscribe
Aug 26, 2006 | 04:49 PM
How many of you are running the feed line off of a firewall relocation kit other then running a brass fitting straight off of the block. I'm wondering because i am kind of weary of running a heavy fitting off of the block. Also, who sells the firewall oil line relocation kits?
Reply 0
Aug 26, 2006 | 05:06 PM
steve@steathmode
and or fast turbo
sells firewall kits
i run a tuner toys T and a firewall kit
Reply 0
Aug 26, 2006 | 05:34 PM
cool man. Thanks for the quick reply. I will probably be giving either fast-turbo or stealthmode a call monday. I feel alot safer running it off of the firewall.
Reply 0
Aug 26, 2006 | 10:16 PM
Re: (EFvtec Yo!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFvtec Yo! &raquo;</TD></TR><TR><TD CLASS="quote">cool man. Thanks for the quick reply. I will probably be giving either fast-turbo or stealthmode a call monday. I feel alot safer running it off of the firewall.</TD></TR></TABLE>
why is that?
Reply 0
Aug 27, 2006 | 04:38 AM
Re: (Fallen86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fallen86 &raquo;</TD></TR><TR><TD CLASS="quote">
why is that?</TD></TR></TABLE>
A friend of mine thinks that brass fitting is too heavy and with the vibration of the car it would break off into the block. Also I am going to run an aftermarket gauge and it would be alot easier and give me more access if it was on the firewall.
Reply 0
Aug 27, 2006 | 08:57 AM
Re: (EFvtec Yo!)
plus another thing i like about running the T by the firewall is you keep the SS line away from the ALT.
Reply 0
Aug 27, 2006 | 09:19 PM
Re: (JDustinM)
oh I See. nice, somting new everyday
Reply 0
Aug 27, 2006 | 09:32 PM
Re: (Fallen86)
I run the TunerToys brass tee off the block with no problems.
Reply 0
Aug 27, 2006 | 09:46 PM
Re: (EK k kay)
what about the sandwich adapter. you can run everything off of that real simply too.
Reply 0
Aug 27, 2006 | 09:48 PM
Re: (EK k kay)
Ive ran a a firewall kit on my car for over 3 years and never had one problem. Ive seen 2 people i know break the brass fittings off in the back of the block.
Reply 0
Aug 27, 2006 | 10:11 PM
Re: (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">what about the sandwich adapter. you can run everything off of that real simply too.</TD></TR></TABLE>
I have both the firewall kit, and the sandwich adapter. Today I was doing my turbo install and started up my motor after putting in about a gallon of antifreeze in the new radiator, and oil of course.
I started up my motor, and left it on for a bout 1 minute to a minute and a half. I then noticed alot of oil dripping from under the car. I turned off the car immediately, and just checked quickly under the car and I think it was coming from my sandwich adapter/filter. I then had to put about 1 1/4 more quart of oil.
I had to rush out though after that unfortunately so I didn't get to diagnose fully. My friend put it on. I have a blox one. I don't know if there is a specific way of putting it on, tightening it? Not sure, How exactly does it go on? I didn't get directions. Just two brass fittings, and I used one, that matched up with the filter. It did come with a rubber piece on it. It semed pretty self-explanatory, but maybe it was put on wrong???
Thanks for the help.
Reply 0
Subscribe
