oil feed line length
Old Oct 2, 2012 | 06:59 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Icon2 oil feed line length
what is the standard length for the oil supply line off a sandwich plate to a garrett GT turbo on a D series engine?
on a similar note, has anyone done a hard line instead of the typical SS braided rubber lines for both oil feed and water cooling?
Old Oct 2, 2012 | 07:07 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: oil feed line length
Around 3' is "standard"... and Yes, and Yes. I have also hard lined lines for BOV, Wastegate, EBC, ect...
Old Oct 2, 2012 | 07:09 PM
Care to share the experience, tips, parts list and photos? I would prefer to do all of them thy way with short rubber flex portion for the stock appearance.
Old Oct 2, 2012 | 08:02 PM
actually, the only real question about that i have is what did you use to go from the 4AN on the oil restrictor, did you use barb ends, or 4AN tube sleeve and nut?
Old Oct 3, 2012 | 07:33 AM
TKERacer619's Avatar
All AN fittings for the oil feed.
I use a short hard line (originally for brakes) from the parts store that I bent to contour around the turbo and manifold. Mainly to keep the braided line from contacting the manifold and due to the way the turbo is clocked gave me room for the restrictor which I couldn't fit otherwise.
Old Oct 3, 2012 | 07:35 AM
Muckman's Avatar
Moderator in Chief
Just use a string or a rope to measure the length of your route. Too many variables.
Old Oct 3, 2012 | 09:40 AM
DO IT ON ALL FOURS
They sell restrictors that are NPT based... It's not hard really, just like running brake lines or fuel lines. Pretty basic if you ask me. I personally wouldn't use rubber anywhere if you are taking the time to hard line it. As long as everything is attached to the engine, you don't have to worry about ruptures due to flexing.
Old Oct 3, 2012 | 11:30 AM
Looks good. Although I will change back to hard line after a length of braided rubber. Run along the engine block to the source.
D3LSLO
Mar 21, 2004 08:20 PM
beepy
Mar 1, 2004 09:26 PM
Prelude91siT
Jan 19, 2004 06:24 AM
rpm9100
Jun 13, 2003 03:55 PM
Snafu-Si
Jul 2, 2002 07:58 AM
