oil feed from back of block
Old Dec 7, 2003 | 03:33 PM
QUICKERSILV3R's Avatar
Default oil feed from back of block
Ive got a d16y7 and from what I have heard the actual oil pressure sensor ---(I think thats what its called)...is what I tap for oil feed, I have also been told to look for this in between the OIL FILTER and ALTERNATOR..well of course theres nothing in between those two items. Although, there is a little black cover which is obviously covering something and it has one wire coming from it it is exactly above the oil filter about an inch to be exact ..
can ANYONE confirm with me that this is it or do I need to keep searching for my feed line tap?
thanks
Carlton
Old Dec 7, 2003 | 03:35 PM
Johnyquest's Avatar
Default Re: oil feed from back of block (QUICKERSILV3R)
that's the one! pull that rubber cover off w/ your hands, then use a wrench to get it off...
Old Dec 7, 2003 | 03:44 PM
Pfieff's Avatar
Default Re: oil feed from back of block (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">that's the one! pull that rubber cover off w/ your hands, then use a wrench to get it off...</TD></TR></TABLE>
what he said
Old Dec 7, 2003 | 03:59 PM
Default Re: oil feed from back of block (Pfieffdog)
thanks fellas I'm gonna go take care of it right now
Carlton
Old Dec 7, 2003 | 09:58 PM
boredracer408's Avatar
Yeah thats the one. Pull off the rubber cover and use a deep socket 24mm to remove the sensor.
TravisBiggie
Apr 24, 2012 08:01 PM
crxzcracer
Jan 4, 2005 11:56 AM
g2_boosted
Sep 10, 2004 06:22 PM
BlackB18CTeg
May 14, 2003 02:45 PM
freeplay
Sep 8, 2002 06:25 PM
