Oil Filter Location
Old May 13, 2003 | 10:14 AM
BlackB18CTeg's Avatar
Default Oil Filter Location
Where is the Oil filter located to tap oil source for turbo? Looked at posts and some books, but they give close up location, I need to know the general area. Thanks.
Old May 13, 2003 | 10:15 AM
b18bturbo's Avatar
Default Re: Oil Filter Location (BlackB18CTeg)
its the oil pressure sendder its covered wuth black cover that you cna remove and then take socket and open that out add tee into the block 1/8bspt is the thread
Old May 13, 2003 | 10:37 AM
Default Re: Oil Filter Location (b18bturbo)
where is the oil pressure sender tho? Any pics pleasE?
Old May 13, 2003 | 10:50 AM
b18bturbo's Avatar
Heres our pic of one look left of the oil filter its right there
Old May 13, 2003 | 11:10 AM
B18EG6's Avatar
what kind of block is that?
Old May 13, 2003 | 11:19 AM
igo4bmx's Avatar
are you sure its 1/8 bspt and not npt?
please tell me you made a mistake
Old May 13, 2003 | 11:21 AM
b18bturbo's Avatar
Default Re: Oil Filter Location (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">^
what kind of block is that?</TD></TR></TABLE>\
del sol project block 2.1liter
Old May 13, 2003 | 11:22 AM
b18bturbo's Avatar
Default Re: Oil Filter Location (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">****
please tell me you made a mistake</TD></TR></TABLE>
its 100% BSPT fitting is needed the npt might fit but has tendenancy to break if you need a bspt fitting contact flamenco t on here
Old May 13, 2003 | 11:26 AM
RGAZ's Avatar
New User
Definitely 1/8 Bspt. You can get brass adapters to 1/8 npt from Autozone. $5 or less. Sunpro repackages them.
Randy
Old May 13, 2003 | 11:30 AM
igo4bmx's Avatar
ARGH!!!
i bought one for the oil feed line attached to my turbo, but now i need one for the sender on the block to my tee!!
I'm gonna kill someone...(its been 3+ weeks and i've been trying to get my turbo on, but things are always missing that i need)
Old May 13, 2003 | 11:31 AM
igo4bmx's Avatar
Default Re: Oil Filter Location (RGAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGAZ &raquo;</TD></TR><TR><TD CLASS="quote">Definitely 1/8 Bspt. You can get brass adapters to 1/8 npt from Autozone. $5 or less. Sunpro repackages them.
Randy</TD></TR></TABLE>
i've looked everywhere and autozone doesn't carry 1/8 nspt
Old May 13, 2003 | 11:34 AM
b18bturbo's Avatar
contact stan aka flamenco-t here he has plenty of the bspt adapters
Old May 13, 2003 | 12:04 PM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">contact stan aka flamenco-t here he has plenty of the bspt adapters </TD></TR></TABLE>
already done..
thank god i saw this thread....
Old May 13, 2003 | 03:44 PM
Flamenco-T's Avatar
i've looked everywhere and autozone doesn't carry 1/8 nspt</TD></TR></TABLE>
autozone ones are BSP, not BSPT, T stands for tapered.
stan
Old May 13, 2003 | 05:08 PM
PM-Performance's Avatar
Default Re: Oil Filter Location (Flamenco-T)
Autometer got em , thats where i got mine from
Old May 13, 2003 | 05:28 PM
Heres our pic of one look left of the oil filter its right there </TD></TR></TABLE>
what size bolt is that? its covered by a black cover and I need to know in order to remove it.
Old May 13, 2003 | 05:36 PM
intekragsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">
what size bolt is that? its covered by a black cover and I need to know in order to remove it.</TD></TR></TABLE>
15/16 deep socket.
Old May 13, 2003 | 06:58 PM
B18Flip's Avatar
Default Re: Oil Filter Location (intekragsr)
make sure you don't over tighten the fittings, i know someone did some damage to their block that way
Old May 14, 2003 | 04:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">
15/16 deep socket. </TD></TR></TABLE>
so do i just pull out the fitting attached to teh end of it and then use a deep socket?
Old May 14, 2003 | 04:25 AM
Screamer's Avatar
Is that a sandwitch adapter for an oil cooler that is between your filter and the block??? If it is, what kind is it and where can I buy one.
Thanks,
Old May 14, 2003 | 06:52 AM
b18bturbo's Avatar
Default Re: Oil Filter Location (Screamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screamer &raquo;</TD></TR><TR><TD CLASS="quote">Is that a sandwitch adapter for an oil cooler that is between your filter and the block??? If it is, what kind is it and where can I buy one.
Thanks,
its actually an oil feed supply block it suppled 1/8npt to - whatever you want to feed 4ports on it
Old May 14, 2003 | 06:55 AM
int3gra's Avatar
how much is that oil feed block?
Old May 14, 2003 | 07:55 AM
b18bturbo's Avatar
Default Re: Oil Filter Location (int3gra)
55 bucks
Old May 14, 2003 | 08:01 AM
Screamer's Avatar
How large is the 1/8npt??? My oil cooler lines are -10NA, will this work???
Old May 14, 2003 | 08:04 AM
b18bturbo's Avatar
nope you need someting like greddy or permal cool adapter.
