oil feed?
Old Feb 9, 2005 | 11:17 AM
jerbear!'s Avatar
Default oil feed?
i just received my oil feed/return lines from cheapturbolines.com. it came with instructions for the return lines but didnt for the feed lines. i did a search and wasnt able to find a specific answer to installing the feed lines (most of the threads we archived and didnt have pics) i was wondering if anybody can give me some sorta of step by step instruction or pics to help me start?
Old Feb 9, 2005 | 12:30 PM
Hyaboosta's Avatar
Default Re: oil feed? (jerbear!)
if it came with a T fitting then you'll have to look in the back of the block by the oil filter and unplug and remove the Oil pressure sensor then put some teflon tape on the thread. do the same for the oil pressure sensor and thread it onto the T then thread the T into the block where the sensor was. Make sure its in there or it's going to be pissin alot of oil. then just connect the oil feed line to the last open port on the T and run the line around the block to the oil feed on the turbo. throw some more teflon on it before threading it on and call it a day.
1990hf
Jan 13, 2009 12:55 PM
goldex420
Apr 6, 2008 05:23 PM
96ej8MR
Sep 11, 2007 01:46 PM
Cisco93Lude
Sep 28, 2006 06:37 PM
zbower7
May 14, 2004 01:42 PM
